How to use auto screen alignment on Dangbei Mars Pro projector?
Keystone Correction Settings
1. Into [Settings] - [Keystone correction] - [Automatic correction]
The automatic keystone correction function is enabled, the frame will be adjusted automatically.
2. Into [Settings] - [Keystone correction] - [Manual correction]
To adjust the four points and the size of the frame.
Dangbei Mars Pro projector support automatic keystone correction,there may be a slight deviation in the correction effect under different usage scenarios, which can be further fine-tuned by manual correction.
