The BenQ MS3081 + projector is the most popular model of the brand, with extremely high sales in China. When the degree of attention increases, the problem will follow. When you want to buy this projector, you will definitely understand the difficulty of its operation. So how to use BenQ MS3081 + projector, can you connect Wifi and mobile phone?
1. How to use BenQ MS3081 + projector
BenQ MS3081 + projector is a traditional projector, which uses LCD display technology and is used in office scenes. Because traditional projectors do not have a built-in intelligent system, if they have Wifi function, they can only be used for screen projection of mobile phones and computers. At the same time, if there is a USB interface, you can access the U disk to read files, film and television resources, etc.
However, the situation of the BenQ MS3081 + projector is a little special. It neither supports Wifi connection nor USB interface, and only has a VAG interface. It can be used to connect a computer with a cable to watch files, watch TV, etc. However, if you connect other equipment, you need to purchase an extension cable to use.
Second, can BenQ MS3081 + projector connect Wifi and mobile phone?
The answer is no, because the BenQ MS3081 + projector system does not have a Wifi connection function, so it cannot be connected to Wifi, nor can it be placed in the same network environment as the mobile phone to screen.
It is worth noting that although the BenQ MS3081 + projector can be wired to a computer, it does not support Apple computers.
To sum up, the BenQ projector has great limitations. Although it mainly promotes high brightness, it cannot be side projected, does not support projection screens, Bluetooth, and set-top boxes are still quite backward. Why so many people buy it?
