ashley
How to Using Wi-Fi to connect SONY OLED TV to the Network? The built-in wireless LAN device allows you to access the Internet and enjoy the benefits of networking in a cable-free environment.
- Set up your wireless router.
For details, refer to the instruction manual of your wireless router, or contact the person who set up the network (network administrator). - Press the HOME button, then select [Settings] — [Network & Internet].
- Select a network you want to connect to and set the password.
If your TV can not connect to the Internet/Network, refer to The TV cannot connect to the Internet/Network.[/URL] page.
- To disable [Wi-Fi], press the HOME button, then select [Settings] — [Network & Internet] — [Wi-Fi].
- For smooth video streaming:
- Change the setting of your wireless router to a high-speed networking standard such as 802.11n if possible.
For details on how to change the setting, refer to the instruction manual of your wireless router, or contact the person who set up the network (network administrator). - If the above procedure does not deliver any improvement, change the setting of your wireless router to 5GHz, which may help improve the video streaming quality.
- The 5GHz band may not be supported depending on your region/country. If the 5GHz band is not supported, the TV can only connect to a wireless router using the 2.4GHz band.
- To use WEP security with a wireless router, select [Settings] — [Network & Internet] — [Easy setup] — [Wi‑Fi].
- The network-related settings that are required may vary depending on the Internet service provider or router. For details, refer to the instruction manuals provided by the Internet service provider or those supplied with the router. You can also contact the person who set up the network (network administrator).
- If you select the [Show password] option in the password entry screen, the exposed password may be seen by other individuals.
