How to view pictures in 4K resolution on Sony TV?
Popo
You can connect a digital still camera/camcorder that supports HDMI 4K output to HDMI IN of the TV to display high-resolution photos stored on the camera. You can also display high-resolution photos stored in connected USB devices or your home network. A picture with a 4K or higher resolution can be displayed in 4K resolution (3840×2160). Here is the guide how to view pictures in Sony TV.
1. To view pictures stored on a USB device or network device in 4K resolution​
  1. Connect the USB device or network device to the TV.
  2. Press the HOME button, and select Apps from the Home menu, then select [Media Player].
    If the supplied remote control has an APPS button, you can press the APPS button.
  3. Select the USB device name or network device name.
  4. Select the folder, and then select the file to play.
To view pictures stored on a USB device or network device in 4K resolution.png
2. To view pictures stored on a digital still camera/camcorder​
  1. Connect a digital still camera or camcorder that supports HDMI output to the HDMI IN jack (socket) of the TV, using an HDMI cable.
  2. Press the INPUT button repeatedly to select the connected device.
  3. Set the connected device to 4K output.
  4. Start playback on the connected device.
3. To view pictures in 4K resolution with higher quality​
To display a picture from a device connected to the HDMI input terminal in a higher quality HDMI format*1, set [HDMI signal format] in [External inputs].
HDMI signal format
To change the HDMI signal format setting, press the Quick Settings button on the remote control, then select [Settings] — [Channels & Inputs] — [External inputs] — [HDMI signal format] — the HDMI input you want to set.
Follow the on-screen instructions, and set the HDMI signal format from the HDMI input terminal to a suitable format below. Available HDMI signal formats depend on your model and HDMI input.
  • Standard format
  • Enhanced format
  • Enhanced format (Dolby Vision)
  • Enhanced format (4K120, 8K)
  • Enhanced format (VRR)
