Hardon Williams
- 1 Specs
- 2 Which to get
When it comes to projectors, the choice often boils down to two core aspects: brightness and versatility. On one hand, we have the InFocus IN5134 Projector, boasting an impressive 4000 lumens and a reputation for delivering quality images with true-to-life colors. It's built for those who prioritize clarity and reliability in various lighting conditions, making it an ideal option for presentations or home viewing where ambient light can be a factor.
On the other hand, the COI Portable Projector takes a different approach, positioning itself as a smart projector tailored for the streaming enthusiast. With its Netflix licensing and seamless access to popular apps like Prime Video and YouTube, it caters to a modern audience that values convenience and instant access to content. Plus, with features like 5G WiFi, Bluetooth connectivity, and a native 1080p resolution, it promises a rich viewing experience—albeit with lower brightness at 1000 ANSI lumens.
So, which projector aligns better with your needs? Is it the robust performance of the InFocus IN5134 for those critical moments, or the COI Portable Projector’s streaming capabilities that fit into today’s on-demand lifestyle? Let's dive deeper into the specifics to help you determine which one may serve you best.
I'm torn between two projectors and could use your input!
On one hand, we've got the **InFocus IN5134 Projector**. It's boasting **4000 lumens**, which sounds great for bright images and true-to-life colors. Plus, it’s easy to maintain, which is a big plus in my book. But I’m curious about how it performs in terms of sound quality and overall system functionality. Are there any downsides that I should be aware of?
Then there's the **COI Portable Projector**. This little beast is officially licensed for Netflix and has a ton of features, like quick access to popular streaming services and a solid native **1080p FHD quality**. The **15,000:1 contrast ratio** and **1000 ANSI Lumens** sound promising for image quality, and the **5G WiFi and Bluetooth** capabilities are super convenient. But I wonder how the sound holds up, especially if I want to use it for outdoor movie nights. Are there any major drawbacks here?
So, based on picture quality, sound quality, and any other potential downsides, which one do you think I should go for? Thanks for your help!
Specs
| Parameter | InFocus IN5134 Projector | COI Portable Projector |
Reference Price | $2798 | $499.99 |
Recommended Uses | - | Gaming |
Built-In Media | - | UNO5 Projector, Remote Control, User Manual, Power Cable |
Highlight | 4000 lumens Quality images and true-to-life colors Easy to maintain | |
Screen Size | - | 60 Inches - 2E+2 Inches |
Throw Distance | - | 1 - 1 |
Contrast Ratio | 3000:1 | 15000:1 |
Maximum Resolution | - | 1980 x 1080 |
Native Resolution | 1280 x 800 | 1920 x 1080 |
Brightness | - | 1000 lumen |
Display Type | LCD | LCD |
Picture Enhancement | - | HDR10, Dolby |
Other Features | internet-ready, speakers | Netflix Officially-Licensed, 1000 ANSI Lumens, Dolby & HDR10, 4K Support, Auto Focus & Keystone, Full-sealed Optical Engine, WiFi & Bluetooth, True-to-Life Colors |
Video Encoding | - | AVC |
Lamp Wattage | 245 Watts | - |
LightSource Life | 2000 Hours | 30000 Hours |
Controller Type | Button Control | Remote Control |
Control Method | - | App, Remote |
Connectivity Technology | HDMI | HDMI,USB,AV & Audio Out,Chromecast,Bluetooth |
Compatible Devices | - | Laptop, Gaming Console, Tablet, Smartphone |
Wattage | 375 watts | - |
Which to get
Hey everyone.I'm torn between two projectors and could use your input!
