Elena
The first batch of JMGO U2 is going to be shipped from Sep. 24th, many consumers are looking forward to this tri-color laser projector, so let's see the JMGO U2 review.
JMGO U2 Specification
JMGO U2 projector uses a three-color laser light source with a brightness of 3600ANSI lumens and supports 4K resolution. In addition, it has 4 electromagnetic speakers that and supports wireless transmission technology.
1. Picture Quality
JMGO U2 tri-color laser TV adopts 114% BT.2020 color gamut technology.
At present, the color standard of the mainstream TV is DCI-P3, and the color standard adopted by the first-level cinema IMAX Cinema is ALSO DCI-P3, while the color gamut of JMGO tri-color laser TV is 159% of it. That is to say, in the color of this standard viewing experience, JMGO U2 is completely ultra cinema treatment.
Actually, the JMGO U2 TV stands out in color because of its tricolor laser technology. Tri-color laser uses three separate RGB laser sources to synthesize color, because of the high purity of laser source, so the performance is a wide color range, better tolerance.
Besides, JMGO U2 has a 3600 ANSI lumen(with ALR screen, 2400 ANSI lumen without screen) high brightness.
| Contrast Ratio | 15000:1 | Dolby Audio | Certified |
| Projection Screen Ratio | 16:09 | HDMI | 2 Way HDMI 2.0 (1 way HDMI supports ARC return) |
| JMGO Same-Screen Display | Supported | USB 3.0 | 1 (back) |
| 3D Video Playing | Supported | USB 2.0 (for external camera) | 1 (left) |
| HDR10 | Supported | Optical | 1 |
| MEMC | Supported | WiFi 2.4 GHz/5 GHz | Yes |
| Auto Brightness Adjustment | Supported | LAN/Ethernet RJ45 | 1 |
| Eye Protection Mode | Supported | Bluetooth 4.0 | Yes |
| Light Source Safety Certification | Level 2 | Android | Android OS |
| Laser Lifespan | 50,000 hours | Software Platform | Luna OS |
| Sound Power | 15W×2 Fullrange speaker + 10W×2 Tweeter | CPU | MSD6A838 |
| Sound Cavity | 2.4L | RAM | 3GB |
| Brand | Dynaudio | ROM | 32GB |
| Technology | Omnidirectional Stereo Compensation Technology | Dimensions (inches/mm W×D×H) | 28.3×15×6.6 / 720×382.35×168.2 |
| DTS-HD | Certified | Weight (lbs/kg) | 28.2 / 12.8 |
1. Picture Quality
