LG Dolby Atmos Sound Bar
ezseun
Cut the cord and bring the theater with you!
The LG Dolby Atmos Soundbar is perfect for those who find that their TV isn't cutting when it comes to immersive sound. This soundbar includes DTS Virtual:X surround processing, two 45W 10-inch drivers, two 3-inch passive radiators, and a built-in decoder for DTS. All this in an all-black package with LG Signature OLED technology gives your home a premium look.
If you want to experience virtual surround sound in your living room without all the hassle of wires or complex setups, then the LG Dolby Atmos Soundbar will be worth your while. This streamlined sound solution will give you a premium at-home audio experience.
LG Dolby Atmos Sound Bar: Connectivity
The LG Dolby Atmos Soundbar will allow users to plug in and play, so setup is easy, and the unit will connect with your TV using Bluetooth. These Dolby Atmos-enabled devices run on HDMI ports, allowing for flexibility in adding more devices. This unit pushes out some serious power starting at 110 dB in volume. This can be boosted up to 130 dB for those particularly raucous nights. While some feature DTS Virtual:X surround processing, some feature DTS Neural:X 7.1 channel decoding for clear stereo sound from movies and games.
The LG Dolby Atmos Soundbar can also be used without your TV, thanks to the Bluetooth and auxiliary ports available here. This lets you put on some great tunes and run them through this premium sound solution.
Even while Bluetooth is supported by the vast majority of soundbars, LG's soundbars go a step further by enabling Wi-Fi wireless playback and having built-in compatibility for Google Chromecast.
LG Dolby Atmos Sound Bar: Excellent Build Quality
LG soundbars are typically quite well-built with more cheap variants. However, competitors cover their soundbars with a black cloth that collects dust and makes the bar seem unclean. Thankfully, all of the LG soundbars tested have a more quality appearance, featuring state-of-the-art brushed metal or textured plastic finishes that look and feel more comfortable and expensive.
LG Dolby Atmos Sound Bar: AI-Enabled​
LG Dolby Atmos Soundbars features adaptive audio that employs an improved algorithm to recognize voices, effects, and frequencies before optimizing the sound by genre for a more immersive experience in each scenario.
LG Soundbars are now compatible with a broader range of AI services. The LG Dolby Atmos Soundbar may be effortlessly controlled using the platform of your choice.
Tips: For 7.1 surround sound, an additional back speaker must be purchased.
The majority of LG's flagships come with just 5.1.2 channels of audio by default. You must buy LG's extra wireless rear speaker kit if you want your favorite 7.1 surround movies to sound their finest on the SL10YG or SK10Y. Thankfully, the 2020 LG SN11RG is expected to come with 7.1.4 channels out of the box. However, compared to manufacturers like Sony and Nakamichi, who have had full 7.1 devices on the market since 2017, the firm is rather late to the game.
Price​
With varieties of models of soundbars from LG, you can get cost-effective LG Dolby Atmos Sound Bar either at walk-in stores or on online stores like Amazon. The LG Dolby, Atmos Soundbar, is available on Amazon at around $380 lesser or more, depending on the quality, specification, and latest technology. With a few hundred bucks, you'll get a sound solution that will get you the most immersive audio experience possible at the lowest price point possible.
Varieties Available in the Market​
The following varieties in the market feature incredible audio stream through their soundbars. Also, they came with speakers that feature characteristics of Dolby Atmos sound systems. They are purposely designed to create immersive sound to fill gaps in previous sound formats. They are designed to bounce the sound from a ceiling, giving users an immersive experience. Top of the line LG Dolby Atmos Soundbars include;
  • LG SN11RG
  • LG SN10YG
  • LG SN9YG
  • LG SN8YG
  • LG SN7Y
  • LG SP9YA
  • LG SP8YA
  • LG SP11RA
  • LG SJ9
fufuuf
Atmos adds a vertical dimension to the audio output. So, sound comes at you from all directions, not just front, left, right, and rear, but also from above.
