Pocketbeam vs ALLIWAVA: Which Portable Projector Delivers Better 4K Quality and Smart Features for Your Movie Nights?
shootamcg
  1. 1 Specs
  2. 2 Which to get
Today, we’re diving into a side-by-side comparison of two portable projectors that promise to elevate your viewing experience: the Pocketbeam Portable Smart 4K UHD Projector and the ALLIWAVA Mini Portable Projector.
On one hand, we have the Pocketbeam, boasting seamless connectivity with multiple ports and a user-friendly auto correction feature. It claims to make every movie night feel like a personal cinema with its impressive 4K resolution. But does it live up to that promise when it comes to real-world performance?
On the other hand, the ALLIWAVA projector steps into the ring with upgraded 4K FHD capabilities and an eye-catching brightness level of 12000 lumens. With features like auto vertical keystone correction and modern WiFi 6 connectivity, it seems ready to adapt to whatever viewing environment you throw at it. But can it really compete with the Pocketbeam’s established reputation for clarity and ease of use?
Join us as we dissect the details, weigh the pros and cons, and ultimately help you decide which projector deserves a spot in your home entertainment setup.
Specs​
Pocketbeam Portable Smart 4K UHD Projector Smart Projector​
ALLIWAVA Mini Portable Projector Outdoor Projector​
$89.99​
$129​
Home Cinema​
Home Cinema​
User Manual​
Projector​
【Multiple Connections】Equipped with HDMI, USB, and 3.5mm audio ports, ensuring seamless connectivity for all your devices.
【4K Home Cinema】Experience every visual detail in stunning clarity with vibrant 4K resolution. Perfect for streaming new blockbusters or reliving your favorite classics. Enjoy the best seat in the house, every time.
【Auto Correction】Featuring ±40° vertical keystone correction and a zoom range of 75% to 95%, it allows for easy, precise adjustments without needing to move the projector. One press for the perfect fit on your screen.
【Upgraded 4K FHD 1080P Mini Projector】This ALLIWAVA HY320 portable projector doesn't just support 4K native 1080P, it also boasts an impressive brightness level of 12000 lumens. With the latest NTSC color technology, the 4k projector brings every scene to life with richer, more accurate colors and unmatched clarity. Whether you're watching your favorite movies, watching new TV shows, or playing video games, this projectors provides a truly immersive experience.
【Auto Vertical Keystone Correction & 180°Rotatable】The Smart projector comes with built in precision sensors that enable auto vertical keystone correction. This feature automatically adjusts the distorted image, ensuring it always displays in the correct shape and proportion. This short throw projector also features a robust 180° adjustable bracket, allowing you to easily adjust to the ideal projection angle whether you're lying in bed, sitting on the couch, or viewing from any angle at home. Experience a custom home theater atmosphere. (Note: The best viewing angles are 45°, 90°, 180°. If you choose to watch at 180°, please select the projection mode: ceiling projection front/rear.)
【Projector with Wifi6 and Bluetooth 5.0】Choose the HY320 outdoor projector, enjoy super fast wireless connectivity with latest dual band WiFi6( 5GHz & 2.4GHz) technology. It gives you a smooth, no lag experience watching HD movies or gaming. This video projector is also equipped with Bluetooth 5.0, so you can connect wirelessly to Bluetooth speakers or headphones easily. And the built in quality stereo speakers make the sound even better, giving you a deep and broad audio experience like in your own private cinema, perfect for parties, outdoor movie nights, or just chilling out.
2.99 - 10​
2 Meters - 6 Feet​
1500:1​
1280 x 720​
1024 x 720​
12000 Lumen​
LED​
3d-Ready​
Android TV, Built In Stereo Speakers,, 12000 Lumens, Native 1080P & 4K Supported, After-sales email: [email protected],, Auto Vertical Correction, Manual Focus ,, Projector Remote doesn't come with batteries, Ultra fast WiFi 6 & 2.4G+5G Dual band, Bluetooth 5.0​
Bluetooth, Wi-Fi, HDMI, 3.5mm Jack​
Bluetooth​
Laptop, Television, Smartphone​
60​
Mount Type​
Tabletop Mount​
Ceiling Mount​
Which to get​
Trying to decide between the **Pocketbeam Portable Smart 4K UHD Projector** and the **ALLIWAVA Mini Portable Projector** has me a bit torn, so I’m hoping to get some insights from you all!
First up, the **Pocketbeam** offers stunning **4K resolution**, which sounds fantastic for movie marathons. It has all the necessary ports for easy connectivity, which is a plus. However, I’m wondering how its sound quality holds up since it doesn’t specifically mention any built-in speakers. The auto correction feature is a neat touch but does it really do the job effectively?
On the other hand, the **ALLIWAVA** boasts **native 1080P** support and an impressive **12000 lumens** brightness level, which seems great for outdoor use or well-lit rooms. Plus, the **built-in stereo speakers** sound like a solid choice for an immersive experience. The **WiFi6** and **Bluetooth 5.0** capabilities make it super versatile, but how does the picture quality stack up compared to the Pocketbeam?
I’m also curious about any potential downsides of each. Is the **ALLIWAVA** really as portable as it claims? And does the **Pocketbeam** have any glaring issues that I should be aware of?
Would love to hear your thoughts on which one you think is worth the investment!
