- 1 Specs
- 2 Which to get
In a world where portable projectors are increasingly popular, two contenders stand out: the Polocsh Mini Projector and the JIN HONG JIE Mini Projector. Both promise convenience and quality, but how do they stack up against one another in real-world scenarios?
The Polocsh Mini Projector boasts ultra-compact design and a built-in Android 11.0, allowing users to stream their favorite content without extra devices. Its 180° rotating projection and impressive brightness of 10,000 lumens make it versatile for various settings, whether you're indoors or outdoors. Automatic keystone correction is an added benefit, ensuring a hassle-free viewing experience.
On the other hand, the JIN HONG JIE Mini Projector claims to deliver a competitive viewing experience, but does it match the Polocsh in terms of portability and functionality?
In this video, we’ll dive deep into the specifications, real-life performance, and user experiences of both projectors. Join us as we uncover which one truly deserves the title of your next portable projector.
**Polocsh Mini Projector**: It’s got Android 11.0 built-in, which means I can stream Netflix and YouTube without having to buy extra devices—huge plus! It’s super compact at just 1.17lb and promises high brightness with 10,000 LM, which sounds perfect for outdoor movie nights. The 180° rotating projection is intriguing since I could project it on walls or ceilings. Plus, automatic keystone correction sounds like a dream for quickly fixing any skewed images. But I’m curious about the overall picture and sound quality—do those compact projectors really hold up? And what about the potential downsides?
Now, I haven’t gotten the deets on the **JIN HONG JIE Mini Projector**, but I’m wondering how it compares in terms of picture quality, sound, and any cool features. Does anyone have experience with either of these? Which one should I go for? Thanks!
Specs
| Parameter | Polocsh Mini Projector Portable Projector | JIN HONG JIE Mini Projector |
Reference Price | $80.99 | - |
Recommended Uses | Indoor/Outdoor | Home Cinema |
Built-In Media | power cord, HD cable, remote control, smart projector, manual | Power Cord, HDMI Cable |
Highlight | 【Ultra Compact | Built-in Android 11.0】Polocsh smart projector with the latest Android TV 11.0, no need to buy additional exorbitant devices, after connecting Wi-Fi, you can watch Prime Video, Netflix, YouTube and other your favourite channels and videos on the big screen. Weighing only 1.17lb and featuring a compact design that fits in the palm of your hand, the mini projector combines compactness, high brightness and high image quality, so you can enjoy high-quality cinema effects indoors or outdoors 【180° Rotating Projection】Portable projector is equipped with a 180° rotatable bracket, which can be projected onto a white wall or ceiling in your home, and you can enjoy the wonderful content while lying daown, making free and flexible projection possible! The HY300Pro boosts the brightness of the small projector up to 10,000 LM,and it support 1080p video decoding, which makes the projected colours clear and natural, and allows you to present vivid and lifelike cinematic images. Whether you're camping, travelling or on the patio, you can enjoy the ultimate immersive experience 【Auto Keystone | 1:0.9 Short Throw】Bluetooth Projector also features automatic keystone correction, which automatically corrects skewed images whether placed horizontally or at an angle, quickly adjusting to the best picture. With a projection ratio of 1:0.9, video projector is ahead of most small projectors on the market, projecting 40-130 inches and reducing the distance to 19.7''-118''. In addition, manual focusing is supported, making it easy to get a clear image in just a few seconds. Providing you with unrivalled convenience | - |
Screen Size | 40 Inches - 130 Inches | N/A - 1E+2 Inches |
Throw Distance | 3.6 Feet - 11.8 Feet | 5E+1 Inches - 8 Meters |
Contrast Ratio | 10000:1 Pixels | - |
Maximum Resolution | 1920 x 1080 Pixels | 1920 x 1080 |
Brightness | 12000 Lumen | 500 lumen |
Display Type | LCD | LCD |
Picture Enhancement | - | Slow Launch Imaging Technology |
Other Features | Built-In Speaker, Portable, Lightweight, 180° Rotatable, Short Throw | Portable |
Video Encoding | AVC | H.264, H.265 |
Lamp Wattage | 60 Watts | - |
LightSource Life | - | 3E+4 Hours |
Controller Type | Remote Control | Button Control |
Control Method | Remote | App |
Connectivity Technology | Bluetooth, USB, HDMI, 3.5mm Jack | HDMI |
Compatible Devices | Laptop, Gaming Console, Smartphone, Speaker | Laptop, Gaming Console, Smartphone |
Wattage | 50 watts | 1E+1 |
Mount Type | Projector comes with its own feet, no need for additional installation | Portable Mount |
L x W x H | 3.97"L x 3.5"W x 6.69"H | - |
Which to get
So, I’m torn between two mini projectors and could really use your insights!**Polocsh Mini Projector**: It’s got Android 11.0 built-in, which means I can stream Netflix and YouTube without having to buy extra devices—huge plus! It’s super compact at just 1.17lb and promises high brightness with 10,000 LM, which sounds perfect for outdoor movie nights. The 180° rotating projection is intriguing since I could project it on walls or ceilings. Plus, automatic keystone correction sounds like a dream for quickly fixing any skewed images. But I’m curious about the overall picture and sound quality—do those compact projectors really hold up? And what about the potential downsides?
