The Redmi Smart TV MAX 98" launched by Redmi in 2020 became the most worthwhile super-sized TV at that time due to its high-cost performance. Now, Redmi has once again brought a super-sized TV, the Redmi MAX 100". Let's take a look at this Redmi MAX 100 review.
The Redmi MAX 100 TV is equipped with a 4GB+64GB large storage combination, which ensures smooth operation and provides users with large-capacity storage space. Users can download the APP worry-free and store high-definition photos and videos.
The Redmi MAX 100" screen has 94% of the P3 color gamut and 99.5% of the NTSC wide color gamut. Each TV will be color calibrated before leaving the factory, so that ΔE < 2, which achieves the color accuracy of professional monitors.
Not only color, the Redmi MAX 100" TV has achieved breakthrough improvements in brightness, contrast, and details of light and dark levels. It has a peak brightness of 700nits and 192 backlight partitions. Each partition can present 4096 levels of light and dark changes, making the screen light more layered and allowing the dark parts to display more details.
At the same time, the Redmi MAX 100" giant-screen TV supports dynamic alpha value optimization and is equipped with a Light Sensor light sensor. It can automatically sense changes in ambient light and automatically adjust the screen brightness, allowing the TV to automatically optimize the brightness, thereby enhancing the viewing experience.
The Redmi MAX 100" TV also achieves "HDR Slam", which supports Dolby Vision, HDR10+, HDR10 and HLG. Users can get more vivid picture quality when watching movies.
The biggest help from 120Hz is in gaming. The Redmi MAX 100" giant-screen TV is equipped with an HDMI 2.1 interface that supports 4K 120Hz signal input. For console players, this will significantly improve the gaming experience.
At the same time, the Redmi MAX 100" TV supports FreeSync Premium, enabling 120Hz display devices to achieve no tearing/low flicker/low latency.
For more info, refer to Xiaomi TV Forum.
1. Redmi TV MAX 100 Review: Appearance
The 100-inch panel of the Redmi MAX 100" giant-screen TV brings a very shocking visual effect. The frame of the TV is very narrow, not only on the top, left and right sides, but also at the bottom. With a 100-inch screen, it brings A more immersive viewing experience.2. Redmi TV MAX 100 Review: System
Redmi MAX 100-inch giant screen TV is equipped with MTK 9650 high-end TV chip, using 22nm process, quad-core A73 CPU architecture + Mali G52 MC1 GPU architecture + 1T computing power APU. With the support of this high-end chip, a breakthrough upgrade of audio and image quality is achieved, and it also provides extremely smooth system performance.The Redmi MAX 100 TV is equipped with a 4GB+64GB large storage combination, which ensures smooth operation and provides users with large-capacity storage space. Users can download the APP worry-free and store high-definition photos and videos.
3. Redmi TV MAX 100 Review: Image
The Redmi MAX 100" giant screen TV is equipped with a 4K screen with a resolution of 3840×2160. The finest text can also be displayed clearly on the Redmi MAX 100" giant screen TV. With high resolution and large screen size, the viewing experience of users will be significantly improved.The Redmi MAX 100" screen has 94% of the P3 color gamut and 99.5% of the NTSC wide color gamut. Each TV will be color calibrated before leaving the factory, so that ΔE < 2, which achieves the color accuracy of professional monitors.
4. Redmi TV MAX 100 Review: Audio
The Redmi MAX 100" TV has passed the IMAX ENHANCED top audio and video certification. The TV is equipped with a dual-channel 2*15W four-speaker unit. Each channel is equipped with an independent high-frequency unit, which makes the sound more layered. It supports Dolby Atmos, which can bring a more shocking sense of presence.5. Redmi TV MAX 100 Review: Gaming
The screen of the Redmi MAX 100" TV supports a high refresh rate of 120Hz and supports 120Hz MEMC technology. With the blessing of dual 120Hz, the TV will have better performance in terms of video fluency.The biggest help from 120Hz is in gaming. The Redmi MAX 100" giant-screen TV is equipped with an HDMI 2.1 interface that supports 4K 120Hz signal input. For console players, this will significantly improve the gaming experience.
6. Redmi TV MAX 100 Review: Summary
The advantage of the Redmi MAX 100" TV is not only the huge screen size, but also the good performance of picture quality, color and high brush. If you have enough budget and space in your home to put down a 100-inch TV, then the Redmi MAX 100" TV is a very recommended product.For more info, refer to Xiaomi TV Forum.
