mufcroberts
- 1.1 Unboxing Experience
- 1.2 Display
- 1.3 Viewing Experience
- 1.4 Features
- 1.5 System Experience
- 2 Conclusion
| Parameter | ROMIX Mini Portable Pocket Smart Projector | KODAK Ultra Mini Projector | AKASO WT50 Mini Projector |
Picture | |||
Reference Price | $268 | $179.99 | $269.99 |
Recommended Uses | Education, Home Cinema, Business | Home Cinema, Gaming, Business | Home Cinema, Gaming |
Built-In Media | Projector, Remote control, Bag, Tripod, HD-IN Line, Power Adaptor, User manual | User Manual, Power Cord, HDMI Cable | 360° rotatable support bracket, possibly others |
Highlight | Touch Panel: Accurate touch control with button operation Display Technology: DLP, HD 4K decoding Screen Size: 30-200 inches Keystone Correction: Vertical ±45° Connectivity: HD-IN interface, WiFi hotspots, EShare app Device Compatibility: iPhone, iPad, Windows, Android Bluetooth: 4.1 WiFi: 2.4G/5G AC Audio Capability: Connects to Bluetooth speakers | Optical Engine: Advanced DLP with superior LED brightness, exceptional color accuracy, pristine picture quality (best in dark to dim-lit rooms) Size: Smallest and lightest DLP projector, palm-sized for easy portability Compatibility: Onboard media player, built-in speakers, 3.5mm input, integrated HDMI, USB, MicroSD; HDMI compatible with Android and tablets Ease of Use: Simple plug-and-play; no complicated buttons or menus Color Display: Capable of displaying 16.7 million colors for rich detail in games, movies, and slideshows | Size: 5.7 x 3.15 x 0.79 inches Weight: 0.64 lbs Battery: 5000mAh, ~2 hours projection Projection Technology: DLP (0.2DMD chip) Image Quality: Clear, sharp, no pixelation, high brightness, rich colors Connectivity: Wireless (AirPlay, WiFi display, EShare, DLNA), USB, HDMI, Audio, Micro SD Operating System: Android 9.0 App Support: Over 3 million apps from Google Play Store Control Options: Remote control, touchscreen panel, automatic keystone correction Usage: Home, outdoor activities, entertainment, education, business Note: Check for complete accessories and use original charging cable only |
Unboxing Experience
ROMIX Mini Portable Pocket Smart Projector:
When I first unboxed the portable projector, I was struck by its sleek and compact design. It has a modern aesthetic that would complement any home décor. The build quality feels decent, and while it might not be the most premium-looking device on the market, it certainly has a stylish appeal. The buttons are intuitively placed, and the overall layout makes it easy to navigate, giving me the impression that it was designed with user-friendliness in mind.KODAK Ultra Mini Projector:
The Kodak Ultra Mini Portable Projector impresses with its compact design, easily fitting into the palm of my hand. Its lightweight build adds to its portability, making it an ideal travel companion for both business and leisure. The quality of craftsmanship is evident, as it feels sturdy and well-made. While it may not have the flashy aesthetics of larger projectors, its sleek and minimalistic design is functional and appealing, especially for those who prioritize compactness and ease of transport.AKASO WT50 Mini Projector:
The projector has an impressive design that stands out for its compactness and portability. It’s roughly the size of a Samsung Note and is thicker, but it feels sturdy and well-built. The packaging is top-notch, making the unboxing experience enjoyable. Additionally, the inclusion of a mini tripod adds a nice touch, enhancing its usability for various setups, whether for personal use or artistic endeavors.Display
Screen Size | 30 Inches - 200 Inches | 80 Inches - 80 Inches | 3E+1 Inches - 120 Inches |
Throw Distance | - | 5 Meters - 5 Feet | N/A - 13.78 Feet |
Contrast Ratio | - | 1000:1 | [Probably at least] 1000:1 |
Maximum Resolution | - | 640 x 360 Pixels | 1920 x 1080 |
Native Resolution | 854 x 480 | 640 x 360 | 1920 x 1080 |
Brightness | - | 35 Lumen | 50 lumen |
Display Type | DLP | LED | DLP |
Picture Enhancement | DLP and HD 4K decoding | DLP | DLP |
Viewing Experience
Unfortunately, the viewing experience left much to be desired. Despite the promise of a cinematic experience, the picture quality was far from impressive. I aimed for an 80-inch screen in my backyard, but the image turned out fuzzy and dark, which was disappointing. Even with my computer set to 1080p, the output was more akin to Standard Definition at best. I had hoped to enjoy movie nights outdoors, but instead, I ended up feeling let down by the overall clarity and brightness of the display.• **Pros**:
- Easy to set up and use
- Stylish and compact design
• **Cons**:
- Not true to the 4K advertisement
- Picture quality is fuzzy and dark
- Wi-Fi connectivity issues
- Limited device compatibility
The viewing experience with the Kodak projector varies based on lighting conditions. In dimly lit rooms, the image quality is surprisingly good, with decent clarity and contrast. However, as others have noted, it struggles with brightness when projecting in well-lit environments. The focus wheel can be a bit finicky, and maintaining a clear image requires some patience, especially when adjusting it after the initial setup. The built-in speaker is quite underwhelming, but connecting to an external speaker improves the audio experience significantly.AKASO WT50 Mini Projector:
The picture quality exceeded my expectations, offering crisp and clear images that remain vibrant even when projected onto larger surfaces. However, I did notice that it works best in dark environments; bright daylight can wash out the image. The internal speaker's volume is somewhat lacking, so connecting external speakers via Bluetooth is advisable for a better audio experience. While I encountered some choppy playback with the native YouTube app, using an external device like a FireStick resolved this issue, providing a smoother experience.Features
Other Features | Portable, USB Connectivit, HDMI Connectivity | Built-In Speaker, Portable, Pocket, Built-In Battery, Built-In Media Player | Portable, Digital Keystone Correction, Lightweight, Built In Wi Fi, Short Throw |
Video Encoding | HEVC | AVC | MP4, AVC |
Lamp Wattage | - | 5 Watts | - |
LightSource Life | 30000 Hours | 30000 Hours | 30000 Hours |
Controller Type | Button Control | android, ios | Touchpad Control |
Control Method | Touch | App | Touch |
Connectivity Technology | Bluetooth | MicroSD, USB, HDMI, 3.5mm Jack | Wi-Fi, USB, HDMI, 3.5mm Jack |
Compatible Devices | Smartphone, Tablet, Laptop | Laptop, Computer, Tablet | Smartphone, Gaming Console, Laptop, USB device, HDMI device |
Wattage | 5 watts | 9.25 watts | - |
Mount Type | Tabletop Mount | Tripod Mount | Tabletop Mount |
L x W x H | - | 3"L x 3"W x 0.8"H | 5.71"L x 3.15"W x 0.79"H |
Setting up the projector was relatively straightforward, which I appreciated. I was able to connect it to my computer without too much hassle at first. However, I quickly ran into issues with the Wi-Fi connectivity, as it only seemed to work with wireless headphones or speakers, limiting my options for streaming content. I found myself frustrated trying to connect it to various devices, especially since it didn’t live up to the expectations set by its advertisements.KODAK Ultra Mini Projector:
Setting up the Kodak projector is a breeze, as it requires minimal effort to get started. The manual is helpful for ensuring correct alignment and positioning, especially for tracing or projecting images accurately. I found that connecting it to my devices—whether through HDMI or using an adapter for my iPhone—was straightforward. However, it's worth noting that the lack of Bluetooth capability and the requirement for specific adapters can be a minor inconvenience. Overall, the setup process is user-friendly, making it accessible for anyone, regardless of technical skills.AKASO WT50 Mini Projector:
Setting up the projector was a breeze. It connected easily to my devices, including my phone, which I primarily use for cookie decorating. The wireless setup was quick, and I managed to get it running without needing the recommended app, which is a plus. However, I encountered some minor technical issues, especially when using the remote control, which could be more responsive. The interface could also use some improvement, as it sometimes complicates the user experience.Conclusion
Overall Impression:Overall, my experience with this portable projector was quite disappointing. It promised a lot but ultimately fell short in key areas, particularly in picture quality and connectivity. While I appreciate its ease of use and design, the lack of functionality and the inability to deliver a clear viewing experience make it hard to recommend. It seems destined to be a temporary solution until I can find a more reliable and higher-quality projector.
Pros:• Compact and lightweight design, great for portability
• Easy setup and user-friendly operation
• Good image quality in dark environments
• Sturdy build quality
• Versatile connectivity options with various devices
• Limited brightness, best used in dark rooms
• Short battery life; requires external power for prolonged use
• Focus adjustment can be tricky
• Lacks Bluetooth connectivity and requires additional adapters
• Built-in speaker quality is poor
Overall, the Kodak Ultra Mini Portable Projector serves its purpose effectively as a budget-friendly, portable solution for casual viewing and presentations. While it has its shortcomings—especially regarding brightness and battery life—the compact design and ease of use make it a solid choice for those who need a projector on the go. For anyone who primarily projects in dark environments and can work around its limitations, this projector is a worthwhile investment. However, if you seek a high-quality projector for bright spaces or extended viewing, exploring higher-end options may be advisable.
Pros:• Excellent picture clarity.
• Highly portable and easy to set up.
• Supports HDMI and USB connections.
• Comes with a mini tripod.
• Good customer service.
• Remote control functionality can be inconsistent.
• Battery life is limited to about an hour, which is a significant drawback for extended use.
• The internal speaker is not very loud.
• Some apps, like Netflix, face compatibility issues.
Overall, I find this projector to be an impressive gadget that fulfills its primary purpose exceptionally well, especially for artistic projects like cookie decorating. The portability and picture quality make it a great choice for both indoor and outdoor use. However, the limitations regarding battery life and remote functionality are notable downsides. Despite these issues, the projector's performance and the supportive customer service contribute to a positive experience, making it a worthy investment for anyone needing a compact projector for smaller-scale projects.
