Sainellor Smart Mini vs Aurzen Roku D1R vs VOPLLS Smart Mini - two of them hide the panel specs
tvholic
The thing that stopped me on these three listings was how little any of them actually say. Three projectors, all "1080P" somewhere in the title, and not one of the listings gives me a brightness figure, a contrast ratio, or a throw distance. I've been burned by a mini projector before (fan died at fourteen months, so I'm shopping again), and I've learned that a listing which won't print lumens is usually a listing with a number it doesn't want you to read.
Take the VOPLLS at $139.99. The headline is the licensed Netflix, YouTube and Prime Video apps built in, and that's genuinely the useful part — no streaming stick dangling off the back, no screen mirroring that drops frames every time your phone locks. But the feature bullets repeat the same licensed-apps line twice, which tells me the rest of the bullet list is thin. Nothing about brightness, nothing about the lens, nothing about what the panel actually does. 4.4 stars across 2011 ratings is a lot of feedback and it's holding steady, so people aren't furious, but I'd want to know what they're watching it on before I trust that score.
The Aurzen Roku D1R at $139.99 is the one with real volume behind it: 4.4 stars from 2071 ratings and 5K+ bought in the past month. The catch is buried in the first bullet — a Roku account and internet connection are required for activation. That's not a dealbreaker, accounts are free, but it means this is a streaming appliance first and a projector second. It's also billed as an outdoor portable, and the only spec they give is the power supply: 100-240V AC, 50/60Hz. AC power, not a battery. If you're picturing carrying this to a campsite, check that before you order, because nothing in the listing says it runs untethered.
The Sainellor at $129.99 is the cheapest and the least documented. Built-in Android 14, 10000+ movies through the apps, 4.4 stars from 442 ratings, 500+ bought last month. The rating count is a fifth of the other two, so the score is softer. And "Native 1080P" in a $130 mini is exactly the kind of claim I'd want a screenshot of — native panel resolution and "supports 1080P input" get used interchangeably all the time, and at this price the panel is very likely 720p-class with 1080p decoding. Same suspicion applies to the other two, honestly. None of the three lists a brightness number, so any "20000 lumens" style claim you see in the wild on this tier is fiction.
Who should buy what: if you want the safest bet on streaming apps working out of the box and you have a wall outlet nearby, the Aurzen has the deepest track record. If Netflix built in without a separate account setup matters to you, the VOPLLS is the pick. If $10 decides it, the Sainellor is fine, just go in expecting the panel to be the weak link.
What I actually want to know: has anyone here run the Aurzen D1R on battery, or is it strictly AC? That single answer decides whether it goes in my cart.
What the listings say (as of Nov 20)
SpecSainellor StoreAurzen StoreVOPLLS Store
Price$129.99$139.99$139.99
Amazon rating4.4 (442 ratings)4.4 (2071 ratings)4.4 (2011 ratings)
Bestseller rank#19#4#20
SimonK
Does the VOPLLS have any HDMI input at all, or is it purely app-based? If everything goes through the built-in apps, that rules out a console or laptop, which kills it for me regardless of brightness.
Appholic
Worth adding the Anker Nebula Capsule 3 to your shortlist — it actually publishes lumens (200 ISO) and throw ratio, which is rare in this bracket. Costs more at $399, but at least you're not guessing what you're buying.
