Shaking the screen to kill laser speckle on a TITAN Noir Max, with a warranty note
Roy_Knable
Vibrating a projection screen to break up laser speckle sounds like a forum myth until somebody with a TITAN Noir Max and a written warranty answer from the screen maker actually tries it. That is what one owner over on r/projectors did, and the setup is worth spelling out because it is a very common one: the TITAN Noir Max on a 120-inch Wupro Soft Grey Matte floor-rising screen. Speckle-sensitive enough that ALR screens were unwatchable for them, and still bothered on matte.
Wupro's first response was the honest one. Within spec, matte reduces speckle, it can't eliminate it. What changed the picture was that the owner described the whole vibration experiment to Wupro support in writing before doing anything, and got confirmation that the warranty would still cover the motor and electronics. That step is the part I'd copy. Floor-rising screens are expensive to replace and nobody wants to argue a warranty claim after bolting a transducer to the housing.
The physics is not new. Speckle is an interference pattern from coherent light, and if the surface moves slightly faster than your eye integrates, the pattern averages out into something smoother. Commercial cinemas with laser projection have used screen shakers for years for exactly this reason. The question for a home setup has always been whether you can get enough movement to help without hearing it or seeing the image wobble.
I don't have the owner's exact hardware or settings from the post, so I'm not going to guess at frequencies. If you want to try this, the honest summary is: get the screen maker's blessing in writing first, start with the lowest drive level that does anything, and check the image edges for any visible shimmer before you call it a win. A laser projector you can actually watch beats a lab-grade contrast number you can't.
