Sharp will soon launch the brand's first projector, the product shape is similar to other projectors on the market.
According to informed sources, Sharp's first projector has been put online in offline channels, and the relevant parameters of the product configuration are also exposed in advance.
In terms of product configuration, the Sharp projector uses an RGB+B four-channel LED light source, an all-glass lens, while having 1400 ANSI lumens brightness, support 1080P resolution and HDR10+HLG decoding.
The projector is equipped with fully automatic keystone correction, fully automatic intelligent focus, voice remote control, zoom shift, etc. It supports an O-VISION image quality engine, HIFI sound, motion compensation and other functions.
The Sharp brand currently has plans to expand its product layout, and may subsequently launch a series of new home smart projection products.
