Elena
Skyworth Q41 Pro 75-inch version was released in July. The biggest highlight of this product is the inclusion of SKYWORTH EYE CARE technology.
Compared with the PWM dimming used by the traditional LCD TV, Skyworth Q41 Pro uses a new generation of DC dimming technology, directly control the size of the circuit power/current to control the screen brightness, can effectively eliminate the LCD electric video flash.
Let's take a look of this TV.
1. Appearance
As a high-end Skyworth Q series TV, Skyworth Q41 Pro front gives people the first impression of sufficient unity. The 75-inch screen almost occupies all areas of the front, covering all the screen at a glance. If you look at the screen at a slight interval of 3 or 4 meters, it almost achieves a 100% screen proportion effect, and the visual impression after the bright screen is very impressive.
In terms of detail design, Skyworth Q41 Pro has a hidden camera on the top of the body for taking photos, video calls, AI fitness, gesture operation, remote care and other functional scenes. It is worth mentioning that the camera also turns left and right, supporting the automatic focusing adjustment of 73 degrees for vertical viewing Angle and 152 degrees for horizontal viewing Angle.
1. Appearance
