Sony Laser Projector Released: VPL-P630HZ and VPL-P530HZ
On October 12, Sony released two compact WUXGA 3LCD laser projectors, VPL-P630HZ and VPL-P530HZ, with high brightness, flexible installation and excellent operating performance, which will be available in November 2022.
VPL-P630HZ and VPL-P530HZ Projectors Display
The VPL-P630HZ is 6400 lumens (7000 lumens at the center) and the VPL-P530HZ is 5300 lumens (5800 lumens at the center) – even in a well-lit conference room or lecture hall, it projects a clear image.
Both projectors combine Sony's "True Creation" real-time signal processing, mapping and analysis technology to deliver crisp, vibrant images in high quality.
In addition, both new models support 4K/60p signal input and are compatible with 4K video sources. Whether it's pictures, diagrams, or text, the Real Creation feature further enhances the overall clarity, resolution, and quality of your images. The new "True Text" feature enhances readability and improves the presentation of text material by providing sharper letters and lines.
The small size of the VPL-P630HZ and VPL-P530HZ makes it easy to install on ceilings in conference rooms and classrooms, and the vertical lens shift is up to +55%, the widest range of motion among fixed lens models.
VPL-P630HZ and VPL-P530HZ Projectors New Smart Features
In addition, both projectors can be optimized according to the usage environment. The Smart Bright feature allows users to accurately maintain the contrast and vividness of the picture colors even in bright rooms.
A new intelligent photosensitive function is added, which automatically measures the brightness of the room through the built-in ambient light sensor, and automatically calibrates the brightness and color gain settings of the screen according to the situation.
In addition, the VPL-P630HZ and VPL-P530HZ projectors' auto-start function and automatic signal switching function allow the projector to automatically turn on the projector and switch to the corresponding signal source.
These two projectors are for business meetings. If you are looking for home projector, you'd better come for a smart projector with system, like Dangbei Mars Pro Review, one of the best home smart projector, with 3200 ANSI Lumens and laser 4K resolution.
