Jamsbond
Nearly a hundred days of home life, so many people and home TV have a long time of close contact, not satisfied with the TV picture and sound, want to take advantage of the promotion season to start a new TV or audio equipment, but face a variety of brands? Or you want to completely upgrade your home video system, but you don't know how to do it?
Just want to choose a new TV
If you're thinking about buying a new TV, you've probably seen a lot of video and audio features, and HDR and immersive audio are more and more frequently mentioned concepts.
HDR (high dynamic range) can bring more vivid pictures to the audience. Dolby vision HDR, a combination of HDR and wide color gamut (WCG), can make entertainment content more real and vivid in front of your eyes through amazing brightness, contrast, color and details.
Not only at Dolby's, you can experience Dolby's vision at home. When you are moved by TV entertainment, you will be surprised to find that the original "watching TV" can be so rich and interesting. Compared with ordinary painting surface, Dolby vision HDR can provide unprecedented color, brighter light part and darker dark part. You will see a very delicate, accurate and real picture. It is no longer the artist's dream that "people travel in painting". This is a wonderful home HDR technology, like it or not, eyes know it.
At present, no matter domestic or imported TV brands, top TV manufacturers have been continuously launching TV products supporting Dolby vision. Here are some TV brands listed. You can refer to the following brands to buy a TV that supports Dolby vision. Dolby panoramic sound is now built into the TV set, so you don't need any external equipment at home. You can get a wonderful immersive experience of Dolby panoramic sound through the speaker of the TV set.
There are many brands of TV models such as Sony, Sharp, TCL, LG, Philips, which can support both Dolby vision and Dolby panoramic sound, so that you only need one TV to get the amazing experience brought by Dolby's most advanced audio-visual technology. With a TV that supports Dolby vision and Dolby full view sound, you can watch Dolby vision and Dolby full view sound on the local TV. Many smart TVs can also support the online streaming function of Internet TV. You may have a Dolby version of your content on demand, which can be switched with one click. You can also find the Dolby zone to order rich entertainment content in your favorite Dolby format.
Another use scenario is to play content through a set-top box or player, such as a blu ray player or AppleTV 4K. To make sure you are transmitting Dolby vision signals to your TV, make sure you are using a Dolby vision compatible HDMI cable.
Not satisfied with TV sound system
If you are not satisfied with the sound effect of the local speaker of the TV, you can get richer, clearer and stronger sound effect by adding a soundbar supporting Dolby full view sound.
Echo wall is also called strip speaker. It integrates the decoding and rendering functions of home theater power amplifier and speaker. It is very convenient to set and connect, plug and play. Usually, only a few connecting lines or wireless connections are needed, and it can be quietly integrated with the room decoration.
Compared with the traditional echo wall, the echo wall supporting Dolby's panoramic sound provides a deeper sense of experience and height. Echo wall products support different number of channels, and usually do not need to install multiple speakers in the room. In order to better surround and subwoofer effect, you can also choose products with satellite speakers and subwoofer. You can find echo wall products supporting Dolby panoramic sound by visiting Dolby's official website.
You can connect a set-top box or player to an echo wall that supports Dolby full view sound, and connect the echo wall to a TV that supports Dolby vision. To ensure that the Dolby horizon signal is transmitted to the TV, make sure that you are using a Dolby horizon compatible HDMI cable and that the echo wall is Dolby horizon compatible.
If you are using the streaming media service on the smart TV to play the content online, please transmit the sound of the TV to the echo wall through HDMIARC, and turn on the functions of the TV external audio and CEC control.
Want to completely upgrade the home audio-visual system -- set up a home theater
If you want to pursue the ultimate listening experience, it's your best choice to build a home theater system. Compared with surround sound home theater, supporting Dolby panoramic sound is not very complicated.
You can get the top sound in any of the following ways
Ceiling mounted or ceiling mounted speakers (top speakers)
Use 2 to 4 top speakers to send sound from the top to the listening area. We recommend using four top speakers, which will provide more precise positioning and realistic top sound. You can also choose the number of top speakers according to your actual situation.
Install an additional speaker module (Dolby atmos enable speaker) that can be placed on or near an existing speaker.
