Typical Projector Help question
karvagear
I know this is a common question but I am looking for a projector to purchase. Any help is appreciated.
-Budget: $1000 to $1800.
-Room: Large basement with some windows. Will probably only watch at night. I would like the projection size to be 120 inches. I can set my couch and the projector to be at any distance https://19216801.onl/ https://routerlogin.uno/ .
-Screen: I already purchased the Elite Screens Tripod Tab-Tension CineGrey 5D Series, 124-inch Diag. 16:9, Ceiling Ambient Light Rejecting ALR/CLR Tripod Pull-Up Portable Screen, TT124UHD5 (I liked this because it is portable).
-Purpose: Just watching movies, shows and sports. No gaming
-I live in the U.S.
wheelee
Active member
the Hisense C1 is very popular now in avsforum & is almost always on top of the GC but your screen is ALR so you might have a problem with speckle & same would be for the Jmgo N1U
try to find any Dangbei Mars Pro or the X5 Pro if you can or go with the Benq x3000i or ones from Formovie
wheelee
Active member
so you use ALR with the HS C1?
but they say the speckle will be more worst if you use an ALR screen that's why they recommend matte type for those Triple Laser PJ's
Benq 4k hdr console gaming projector is great. I love this setup, the screen is vividstorm alr floor rising screen.
