ViewSonic X2 is a short-throw projector with a good performance configuration. We will share the parameters and features of ViewSonic X2 below.
The ViewSonic X2 projector uses the latest solid-state LED technology. Compared with high-pressure mercury lamps, it has neither mercury nor lamps, making the equipment more environmentally friendly. At the same time, ViewSonic X2 has a longer service life, the LED light source used can provide more than 30,000 hours of use time, and the power consumption is less than half of a typical LCD TV.
When it comes to brightness, the actual brightness of the Ubi X2 reaches 3100 lumens, providing the device with a strong resistance to ambient light, allowing the projector to project a bright picture even during the day.
As for the resolution, the standard resolution of the Ubiquitous X2 reaches 1080P, which supports the projection of clear images and can show the video details better to the user.
ViewSonic X2 adopts Cinema SuperColor+ technology and has 125% Rec.709 color accuracy, which can provide vivid and lifelike colors. In terms of picture processing functions, it supports HDR10 decoding, which makes the color of the picture more delicate and the details of light and dark clearer.
The ViewSonic X2 is equipped with Harman Kardon speakers, providing powerful performance for the device. It produces deep, loud, room-filling 360-degree sound, perfect for playing music and movies. Plus, it supports Bluetooth connectivity. You can use the ViewSonic X2 as a Bluetooth speaker, or output audio from a projector to a Bluetooth headset.
In terms of picture correction function, the Ubiquity X2 supports manual focus and four-way keystone correction, allowing the device to project a square and clear picture even when installed on its side.
As for the projection lens, it is equipped with a 1.2x optical zoom lens with a projection ratio of 0.69-0.83:1, allowing the device to project a 100-inch image with a projection distance of only about 1.5 meters.
ViewSonic X2 is equipped with a wealth of interfaces, it supports connection to computers, game consoles, amplifiers, audio, mobile hard drives and other devices. It greatly improves the expansibility of the equipment, makes the projector more practical, and meets the various needs of users.
Through detailed parameter configuration analysis, it can be found that the overall configuration of the ViewSonic X2 projector is good. It has excellent picture quality and can meet the needs of users for watching movies on a large screen. In general, it is a projection device suitable for home use.
1. Projection light source
2. Projection image quality
3. Picture color
4. Audio configuration
5. Projection function
6. Projection interface
