vivian334
Yamaha has been cultivating for many years, with various purchase channels and many audio-visual products. Some models may be different in color and channel, such as Yamaha RX-V585 and RX-V53
These Yamaha AV amplifiers also support wireless surround speaker expansion. If you don’t have a surround speaker cable, it is very convenient. If you want to consider that the old model V583 is also on sale, the minimum is less than 3k, you can upgrade to support eARC, the details of the upgrade of Yamaha RX-V585 and RX-V53 are shown in the table below.
However, in recent years, the new products of Yamaha AV amplifiers seem to be on the high-end AVENTAGE series. The following is a list of Yamaha ’s entry-level panoramic sound AV amplifiers, all of which are 2018 models. RX-V 3, 4, 5, 6 have always been Yamaha. The mainstream models of cost-effective products are also focused on output power, interface configuration and calibration function level.
- The better models of Yamaha entry amplifiers are:
- Yamaha RX-V371, which is Yamaha entry-level amplifier. The mainstream 5.1 channel family * can be driven more easily, and the configuration is enough to use surround sound, whether it is surround sound or listening to music. The performance of the
- Yamaha P3500S is a low-end product in the Yamaha P series professional amplifier. The performance of the Yamaha P3500S professional amplifier has not been significantly reduced, but it is different in terms of output power. It provides excellent sound performance and the size of the amplifier. The weight and weight are relatively moderate, making transportation and assembly very easy.
- Yamaha A-S700 optimizes the output of subwoofers or real systems so that you can get the highest audio quality and performance in any system, provides excellent connection flexibility, and the size and weight of the power amplifier are relatively small, which is very convenient .
