Amanda Brown
Active member
Laser TV and laser projector are both imaging products using laser light sources, but there are big differences between them in application scenarios, performance, and price.
Laser TVS are commonly used in home theater, TV viewing, and other Settings, and the current common size of 65 inches or more. Laser projectors, on the other hand, can achieve a larger projection size, suitable for commercial presentations, school education, and other large venues, usually can achieve a projection size of more than 100 inches.
Laser TV uses a laser light source as a light emitting device, which can achieve higher brightness, higher color gamut, and higher contrast, presenting a more realistic picture effect. Laser projectors, on the other hand, have less brightness, gamut, and contrast than laser TVS because they need to focus light onto the screen through projection optical lenses, but still, provide higher picture quality.
Laser TV uses optical devices, and its long life, and can maintain high picture quality and brightness performance. And the laser projector needs to replace the bulb regularly, its bulb life is short, need to be replaced often, and has higher requirements for maintenance and maintenance.
Due to the application scenarios and technical characteristics of laser TV and laser projector, there are great differences in price and ease of use. The price of laser TV is relatively high, and the laser projector because of its wide range of application scenarios and different grades of product choice, the price has a big gap.
To sum up, laser TV and laser projector are two different products. Their differences lie in application scenarios, display effects, service life, and price. Consumers should choose suitable products according to their specific needs
Application scenario
Display effect
Service life
Price and ease of use
