There are many reasons for sound distortion, as follows:
Sound distortion may be cause by the crossover distortion of transistor operating point.
Distortion occurs when the source signal is too strong or too weak.
The equipment is too small to force full sound, which will also cause distortion. It is clipping distortion, and there is a dc signal.
The mixing table, the electronic frequency divider component attack is too bad, the operation is improper and so on, these problems can produce the sound distortion.
If sound distortion occurs in the front stage of the device, it will happen to the back stage. Front stage signal distortion, generally refers to the mixer gain is too large, which is the front stage signal distortion, so in this case the back stage amplifier sound distortion will happen.
