Hardon Williams
Unboxing Experience
- 1.1.1 Wielio Projector:
- 1.1.2 WiMiUS Mini projector:
- 1.1.3 Lisowod Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Wielio Projector:
- 1.3.2 WiMiUS Mini projector:
- 1.3.3 Lisowod Projector:
- 1.4 Features
1.5
- 1.5.1 Wielio Projector:
- 1.5.2 WiMiUS Mini projector:
- 1.5.3 Lisowod Projector:
1.1
Unboxing Experience
- 2 Conclusion
| Parameter | Wielio Projector | WiMiUS Mini projector | Lisowod Projector |
Picture | |||
Reference Price | $99.99 | $129.99 | $139.99 |
Recommended Uses | Indoor | Home Cinema | Projector with Wifi and Bluetooth for Gaming,Mini Projector for Home Cinema,Projector that connects to iphone,projector for camping,outdoor projector,projector with speaker,projector for home,projector for ceiling viewing |
Built-In Media | Projector | 1* HDMI Cable, 1* Lens Cover, 1* S27 WiFi Bluetooth Mini Projector, 1* Power Cord, 1* Remote Control | User Manual*1, Remote*1(No battery included), HDMI Cable*1, L02 Mini Projector*1, Adaptor*1 |
Highlight | Smart OS: Built-in Android OS with access to apps like YouTube, Netflix, Prime Video Connectivity: 5G/2.4G Dual-Band WiFi, Bluetooth 5.1 Resolution: Native 1080P, 4K supported Image Quality: Enhanced contrast and color accuracy Keystone Correction: 4-point adjustment, ±30° range Projection Size: 40 inches to 240 inches Portability: 120° rotatable stand for flexible projection Customer Support: 2-year warranty, 30-day return policy, 24-hour online support | 270° Built-in Stand & Flexibility: Triangular stand, 1/4'' screw hole for mounting, adjustable viewing angles. Streaming Limitations: HDCP copyright limits wireless mirroring for most streaming services; use TV Stick Lite for smoother access. Wireless Capabilities: Supports Airplay (iOS) and Miracast (Android); requires separate casting device for Chromecast. Image Quality: Auto vertical keystone correction, 1080P resolution, 15000:1 contrast ratio, online updates, auto sleep mode, brightness & color temperature adjustment. Connectivity: HDMI, USB, 3.5mm audio port for connecting to various devices; not battery-powered. Support & Warranty: 24/7 email support, 2-year money back guarantee, 3-year repair, lifetime technical support. WiFi & Bluetooth: 2.4G/5G dual band WiFi, Bluetooth 5.2, wired screen mirroring options, upgraded sound system for better audio quality. | Model: Lisowod L02 Mini Projector Price: Under $100 (plus $30 for TV stick) Dimensions: 6.8 x 5.7 x 3.2 inches Weight: 1.5 pounds Projection Size: 6.1" smartphone to 300" cinema display Stand: 360° adjustable, detachable Connectivity: WiFi 6, Bluetooth 5.2 Audio: Dual 8W Hi-Fi speakers Aspect Ratios: 4:3, 16:9 Keystone Correction: Automatic ±30°, manual ±50° Zoom: 70% Streaming Compatibility: Works with TV stick/laptop for Netflix, Amazon Prime, YouTube Eye-care Feature: Blue light protection Usage: Suitable for indoor/outdoor, gaming, education, parties Ports: HDMI, supports various devices |
Unboxing Experience
Wielio Projector:
From the moment I unboxed the Wielio 2025 Smart Projector, I was impressed by its compact design, which makes it portable and easy to move around. It doesn’t take up much space, yet it feels sturdy and well-built. The sleek finish adds a modern touch, making it a stylish addition to any home theater setup or outdoor movie night. Its lightweight nature means I can easily transport it without hassle, which is a big plus for someone who enjoys flexibility in using tech gadgets.WiMiUS Mini projector:
The WiMiUS S27 Mini Projector boasts a sleek and compact design that complements any setting, whether it's a cozy apartment or an outdoor movie night. Its lightweight construction, weighing less than 2 lbs, enhances its portability, allowing me to easily transport it for various uses. The standout feature is its innovative 270° adjustable stand, which not only provides stability but also flexibility in image projection angles, including the ability to project onto ceilings—a delightful surprise I discovered while enjoying movies with my child.Lisowod Projector:
The Lisowod L02 Mini Projector immediately impressed me with its sleek and compact design. Its attractive white finish gives it a modern and premium feel, seamlessly blending into any room's decor. The lightweight construction makes it incredibly portable, allowing me to easily transport it for various uses, whether indoors or outdoors. The included 360-degree adjustable stand adds to its versatility, enabling effortless positioning on any surface, including ceilings for a unique viewing experience.Display
Screen Size | - | 40 Inches - 200 Inches | 40 Inches - 300 Inches |
Throw Distance | 1 - 3.8 | 3.6 - 17.7 Feet | 3.28 Feet - 19.7 Feet |
Contrast Ratio | - | 15000:1 | 20000:1 Pixels |
Maximum Resolution | 1080P Pixels | 1920 x 1080 Pixels | 1920 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 1280 x 720 | 1920 x 1080 |
Brightness | - | - | 20000 Lumen |
Picture Enhancement | - | - | Quantum HDR |
Viewing Experience
Wielio Projector:
The viewing experience has been stellar so far! The image quality is sharp and bright, even in moderately lit rooms, and the colors are incredibly vibrant, making my movie nights feel like a true cinematic experience. I did notice that the built-in speakers are decent but not exceptional, so I plan to connect an external speaker for a more immersive audio experience. The projector also performed well during presentations, delivering crisp visuals that were easy to read. The brightness and clarity of the picture, along with the ability to adjust settings, made it enjoyable for various types of content, from movies to business presentations.WiMiUS Mini projector:
The viewing experience with the WiMiUS S27 has been nothing short of impressive. With a native 1080P resolution and a contrast ratio of 15000:1, the image quality is sharp and vibrant, particularly in darker environments. I was pleasantly surprised at how well it performed even in semi-dark conditions, maintaining clarity and color depth. The projector can create a large image size of up to 200 inches, making it perfect for movie nights in various settings. Although the built-in speakers are adequate for smaller spaces, I prefer using my Bluetooth headphones or external speakers for a more immersive audio experience.Lisowod Projector:
The viewing experience with the Lisowod L02 has been nothing short of outstanding. The projector delivers sharp, vibrant images with rich colors, even in moderately lit rooms. The 1080p resolution and 550 ANSI brightness provide clarity and depth that truly enhance movie nights and gaming sessions. The auto keystone correction and electric focus make it easy to achieve the perfect picture, regardless of the angle or surface. I particularly enjoyed projecting onto the ceiling for a cozy movie night while lying in bed, which added a fun twist to our viewing routine.Features
Other Features | smart projector with wifi and bluetooth, projector with wifi and bluetooth, mini projector, projector, 1080P projector | Portable, Lightweight, ①After-sales: [email protected], Built-In Wi-Fi, Built-In Handle | 360 Ajustable Stand, Electric Focus & Auto Keystone, Portable Mini Size, Built In WiFi, Built In Bluetooth, Built In Speaker, 24/7 Customer Support: [email protected] |
Video Encoding | - | H.265 | - |
Lamp Wattage | - | - | 50 Watts |
LightSource Life | - | 50000 Hours | 29.99 Years |
Controller Type | - | Remote Control | Remote Control Button Control |
Control Method | - | Remote | Remote |
Connectivity Technology | Ethernet | Wired/Wireless/Bluetooth/WiFi/HDMI/USB/3.5Audio | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack |
Compatible Devices | - | Laptop, Television, Smartphone | Laptop, Gaming Console, Tablet, Smartphone, Speaker |
Wattage | - | 200 watts | 48 watts |
Mount Type | Ceiling Mount | Table Mount/Wall Mount/Ceiling Mount | Tabletop Mount, Ceiling Mount, Table Mount, Tripod Monut, Wall Mount |
L x W x H | 3"L x 5"W x 6"H | 4.6"L x 3.9"W x 7.9"H | 6.77"L x 5.65"W x 3.15"H |
Wielio Projector:
Setting up this projector was an absolute breeze! I appreciated the plug-and-play functionality, which required minimal adjustments on my part. The auto keystone feature was particularly useful, allowing me to quickly get the image aligned properly, and the straightforward remote control made navigating options hassle-free. It supports multiple connections including HDMI, USB, and AV, so I was able to connect my Fire Stick, gaming console, and laptop without any problems. The WiFi screen mirroring function worked flawlessly with my phone and laptop, which was a huge convenience for streaming content.WiMiUS Mini projector:
Setting up the WiMiUS S27 was a breeze. After a few moments of perusing the clear instructions, I had it connected to my devices and projecting in no time. The auto keystone correction feature worked exceptionally well, ensuring that the image was perfectly aligned without the need for manual adjustments. I appreciated the multiple connectivity options—Bluetooth, Wi-Fi, and wired connections—that made it seamless to link my iPad, laptop, and even a portable hard drive. While I encountered a minor hiccup with Bluetooth pairing, a quick glance at the instructions solved the issue.Lisowod Projector:
Setting up the Lisowod L02 was a straightforward process, taking only a few minutes to get everything up and running. The clear instructions made it easy to connect to my Wi-Fi and link it with various devices via HDMI or USB. The remote control is intuitive and responsive, with simple buttons that allow for quick adjustments to focus and keystone correction. I appreciated the built-in control buttons for added convenience, ensuring I could easily operate the projector without the remote if needed.Conclusion
Wielio Projector:
Pros:• Excellent image quality with sharp and bright visuals
• Compact and portable design, easy to set up and move around
• Multiple connectivity options including HDMI, USB, and WiFi
• Auto keystone feature simplifies alignment
• Great value for the price
• Built-in speakers are average, external speakers recommended
• Some users experienced issues with auto-focus functionality
• Occasional overheating reported by some users
• Not ideal for gaming due to slight delay in response
Overall, I am thoroughly impressed with the Wielio 2025 Smart Projector. It offers great value for the price, combining excellent image quality with ease of use and portability. While there are minor drawbacks, such as the average built-in sound and occasional overheating, the projector still excels in delivering a satisfying viewing experience for both family movie nights and professional presentations. I highly recommend it for anyone seeking a budget-friendly yet high-quality projector that can adapt to various uses.
Pros:• Compact and lightweight design for portability
• 270° adjustable stand for versatile projection angles
• Excellent 1080P resolution with vibrant colors
• User-friendly setup with auto keystone correction
• Multiple connectivity options including Wi-Fi and Bluetooth
• Built-in speakers are average; external speakers recommended
• Bluetooth connection may experience temporary disruptions
• Limited functionality with certain streaming apps without a TV stick
My experience with the WiMiUS S27 Mini Projector has been overwhelmingly positive. For its price point, it offers remarkable value, combining portability, ease of use, and impressive image quality. The thoughtful design elements, such as the adjustable stand and auto keystone correction, enhance its usability for both indoor and outdoor settings. While there are some shortcomings, particularly in audio quality, the projector's overall performance and versatility make it a standout choice for anyone seeking an affordable and functional projection solution. I would highly recommend this projector to anyone looking to elevate their home entertainment experience!
Lisowod Projector:
Pros:• Excellent image quality with sharp and vibrant colors
• Compact and lightweight for easy portability
• Simple and quick setup process
• Versatile connectivity options (HDMI, USB, Wi-Fi, Bluetooth)
• 360-degree adjustable stand for flexible positioning
• Auto keystone correction and electronic focus for hassle-free adjustments
• Built-in speaker could be louder; external audio recommended for larger groups
• No lens cap included for protection during travel
• Occasional connectivity issues with screen mirroring on certain devices
Overall, the Lisowod L02 Mini Projector has exceeded my expectations for a compact and budget-friendly device. Its combination of excellent image quality, ease of use, and portability makes it a fantastic choice for anyone looking to enhance their home entertainment setup. Whether for movie nights, gaming, or casual presentations, this projector offers impressive performance at an affordable price. I highly recommend it for anyone seeking a versatile, portable projector that delivers a great viewing experience without breaking the bank.
