Nike Kidman
After the success of the Box X96 Mini , this IPTV box supplier is selling the Max version. A box with boosted characteristics for IPTV. Our test & opinion on this box available below.
IPTV X96 Max Box under s905x2 - Hardware Reviews
Characteristics
With the Android X96 Max Box , you can now enjoy your television differently. It is the first Tv box which is equipped with S905X2 technology from Amlogic.
It is also equipped with two USB ports, one 3.0 and the other 2.0 which give you the possibility of connecting it with your computer or your USB keys and your external hard drives.
The X96 Max TV box is also equipped with an HDMI 2.0 output which allows you to enjoy 4K HD videos. Without forgetting the optical port. If you have the right equipment, you will be able to take advantage of this box without any problem.
Memories
The X96 Max box has three versions for its storage capacity. Indeed, there is a version with a storage space of 16g, one with 32g and another with a memory of 64g.
These memories will make it easier for you to keep your applications, but also your files, thus saving you from taking your computer whenever you need a film or other media files in it.
It is also possible to increase its memory with an SD card, making it easier for you to share your files and download content from the web that you can keep on it. It is also possible to use a USB key to store your data. It is therefore a very practical Tv box at all levels.
Connectivities
The TV box X 96 Max is also very efficient in terms of connectivity. Indeed, there are several ways to connect your box with your Smart TV, but also with certain devices at home.
Thus, it is possible to connect your box in wired mode with the RJ45 cable which is supplied in its original packaging. This allows you to connect with a flow of 10 to 1000m depending on the version of the box.
It is also possible to connect your TV box with your internet box with the Wi-Fi connectivity it has. It can thus operate even at a range of 2 GHz, 2.4 GHz and 5 GHz with a good connection speed allowing you to connect to the internet on your TV set.
It is also possible to connect your box with the Bluetooth 4.0 connection. However, the version with a 16G RAM does not have this connectivity and will have to settle for Wi-Fi and the wired network with the RJ4 cable. The X96 Max box is also equipped with an IR connection.
Characteristics
Memories
Connectivities
