SuperM
Many people are now starting to consider buying a home projector without having to put a huge TV in their home. Many users are looking for portability and thinness, and the XGIMI Elfin projector seems to meet the demand in terms of appearance, so is it good or not? Let's take a look at the review.
The XGIMI Elfin projector features a 0.33-inch DMD DLP pico chipset with native 1080p (1920x1080) resolution. Its LED light source is rated at 600-800 ANSI lumens and has a lifetime of up to 30,000 hours. The Polaroid Elfin projector accepts resolutions up to 4K and displays at 1080p.
The XGIMI Elfin projector is equipped with a 1.2:1 throw ratio and it uses automatic vertical and horizontal keystone distortion correction and auto-focus to adjust the image as it moves. The Polaroid Elfin projector also incorporates technology from the latest Polaroid Horizon series, which senses the size of the available display area and automatically fills the image space. It can also avoid obstacles such as plants and wall sockets, resizing the image around them
XGIMI Elfin projector has a built-in Android TV 10.0 streaming platform with wireless dual-band connectivity and supports screen mirroring via Airplay and Polaroid Assistant. Other source inputs for the Polaroid Elfin projector include HDMI 2.0, USB 2.0 and Bluetooth 5.0, and it has two 3 W Harman/Kardon speakers and a headphone output jack.
| Model Name | XGIMI Elfin Projector |
| Display Technique | DLP |
| Display Chip | 0.3" DMD |
| Standard Resolution | 1920 x 1080(1080p) |
| Luminance | 600 - 800 ANSI Lumens |
| Keystone Correction | Auto |
| Throw Ratio | 1.2:1 |
| RAM | 2GB |
| ROM | 16GB |
| Speaker | 2 x 3W |
| System | Android 10.0 |
| Mirroring Dispaly | Chromecast built-in |
| Input Ports | DC x 1 HDMI 2.0 x 1 USB 2.0 x 1 |
| Output Port | 3.5mm headphone x 1 |
| WiFi | Dual-band 2.4/5GHz |
| Bluetooth | Bluetooth 5.0 |
| Noise | < 30dB |
| Size | 192.1 x 194.19 x 48.31 mm |
| Product Weight | 1.98 Pounds |
