XGIMI H2 VS. XGIMI Horizon review, which is better?
Elena
model nameXGIMI HORIZONXGIMI H2
Display TechnologyDLPDLP
Display Chip0.47" DMD0.47" DMD
Standard Resolution1920 x 1080 (1080P)1920 x 1080 (1080P)
Maximum Supported Resolution4096*2160 @ 60Hz4K(3840*2160)
Brightness (ANSI lumens)2200 ANSI Lumens1350ANSI Lumens
Lamp TypeLEDLED
Lamp Life25,000 Hours25,000 Hours
Throw Ratio1.2:11.2:1
RAM2GB2GB
Storage32GB16GB
Operating SystemAndroid TV 10.0 OSGMUI
Chromecast Built-inGoogle Assistant
Input Ports
DC x 1
HDMI 2.0 x 2
USB 2.0 x 2
LAN x 1
DC x 1
HDMI 2.0 x 1
USB 2.0 x 1
USB 3.0 x 1
LAN x 1
WiFiDual-band 2.4/5GHz,
802.11a/b/g/n
Dual-band 2.4/5GHz,
802.11a/b/g/n
Packing ListPOWER ADAPTER * 1
POWER CABLE * 1
BLUETOOTH
REMOTE CONTROL * 1
POWER PLUG * 1
POWER CABLE * 1
HANDBOOK * 1
REMOTE CONTROL * 1
WARRANTY CARD * 1
Elena
XGIMI Horizon​
XGIMI Horizon
Elena
XGIMI H2 projector uses DLP projection technology with a standard resolution of 1920×1080 and a contrast ratio of 10000:1.
With its motion compensation technology and HDR 10 decoding technology, the picture will not be compromised in smoothness. Compared to the 3G high-speed flash memory used in the XGIMI H1S, XIGMI H2 slims down the memory footprint, and it comes with the new system GMUI3.1, which is a comprehensive optimization of the system, making the H2 more responsive and user-friendly.
Elena
XGIMI Horizon has a high brightness of 2200 ANSI Lumens. It uses a LED light source that will only require minimal maintenance and never require to be replaced. It claims that it can last up to 25,000 hours. This is great for cost savings, as a typical light source replacement will typically require multiple lamp replacements.
XGIMI Horizon supports auto brightness adjustment and with Android TV 10.0 OS and Google Assistant.
