XGIMI Horizon Pro vs. Dangbei Mars Pro 4K Projectors, Which is better?
Milabobo
In order to create a higher-quality home theater, a 4K projector seems essential. XGIMI Horizon Pro and Dangbei Mars projector both support 4K native resolution. One is an LED projector, the other is a laser projector, so let's see which one is better.
1. Appearance Design
As a part of the furniture, the appearance design of a projector is also very important. The XGIMI Horizon Pro is silvery-gray in color, with sound holes on three sides and a frosted texture overall. Dangbei Mars Pro projector has a distinctive design, with black as the main body color, suitable for a variety of home environments. The top is made of 2.5D nano glass coupled with aerospace aluminum surrounding a metal heat sinkhole, adding a sense of style to the product. This product has also won the prestigious design awards - IF Award and Red Dot Design Award.
2. Picture and Sound
Picture quality and sound quality are the most important things that users care for in their home theater. Those who choose a 4k projector are sure to be those who seek high-definition picture quality. 3840 x 2160 (4K) native resolution allows both projectors to deliver the clearest picture possible. The XGIMI Horizon Pro offers a brightness of 2200 ANSI lumens, while the Dangbei Mars Pro offers a superb 3200 ANSI lumens, which is very rare for projectors in its price range. You can watch movies even in the daytime with this high brightness. Both projectors are equipped with HDR10+ HLG technology for more realistic films and richer colors.
It is important to note that the XGIMI Horizon Pro uses a traditional LED light source, while the Dangbei Mars Pro uses a laser light source that is high-end cinema-grade ALPD laser technology, so the brightness of the Dangbei Mars Pro can be higher. The laser projector also has an additional Y-segment for color display than the traditional four-segment red, green, blue and white color wheel projector, making it more colorful.
Both projectors are equipped with dual-channel speakers, Horizon Pro with two 8W speakers and Mars Pro with two 10W speakers, both supporting Dolby Audio and DTS-HD & DTS Studio Sound.
3. System and Technology
The XGIMI Horizon Pro uses Android 10.0 and is equipped with RAM 2GB + ROM 32GB, while the Dangbei Mars Pro has upgraded its system configuration with Emotn OS based on Android 9.0 and is equipped with RAM 4GB + ROM 128G. The large memory configuration allows for smoother operation and allows users to download more content.
The Horizon Pro has a built-in Google Play where users can download applications. The Emotn Store configured in the Dangbei Mars Pro is also a perfect replacement for Google Play, which can download applications without logging in and protects the user's privacy even more.
Both products have Auto Screen Alignment and Obstacle Avoidance technology, autofocus and auto keystone correction, more intelligence to help users adjust the screen. Besides, Dangbei Mars Pro is specially equipped with an inductive eye protection function, when someone blocks the lens, the brightness of the projected light will be reduced to protect the human eye. The product has been certificated to the low blue light by the TÜV Rheinland, which can effectively filter out excessive harmful blue light, and reduce eye fatigue.
4. Summary
Overall, the two 4K projectors are a good choice, with the Dangbei Mars Pro outperforming the XGIMI Horizon Pro in terms of overall configuration and performance. But the two products use very different light sources, the Dangbei Mars Pro is a very cost-effective product if you want to try laser products, as other laser products are still expensive. At $100 higher than the XGIMI Horizon Pro, the Dangbei Mars Pro(now on sale on Amazon) uses a more top-notch configuration, plus a variety of technologies and a large memory, making it very suitable for creating a home theater.
wheelee
Active member
NOW we just have to see how reliable these both are.
Both have some boboos is past models & Firmware.
esegan
A strange comparison of Dangbei Mars Pro 4K Laser and 4K Horizon Pro. 4K XGIMI RS Pro2 is higher class than 4K Horizon Pro, has English language and costs about the same. But even 4K XGIMI RS Pro2 2200 lumens is inferior to Dangbei Mars Pro 4K 3200 lumens in terms of brightness and contrast, diode projectors have the best contrast of about 500-550: 1, Dangbei Mars Pro 4K laser should have a contrast of 1000-1200: 1 thanks to ALPD3 laser technology .0.
But still, I would compare Dangbei Mars Pro 4K 3200 lumens and 4K BENQ X3000i 3000 lumens, they have approximately the same brightness, but also contrast, the BENQ X3000i has a native measured contrast of 1200:1, and a dynamic one of about 2200:1.
But Dangbei Mars Pro 4K, like the younger brother X3 1080 32000 lumens, will have superiority in fine settings, namely, Dangbei Mars Pro 4K additionally has settings for 11 RGB gray scale points (5, 10, 20, 30, ... 100) , as well as RGB general, 2-point RGB, gamma adjustment and there is a full set of 18 settings for all colors of 6 CMS.
LisaMo
and Dangbei is good at many advanced technologies
sai
The XGIMI Horizon's projection looks like this, with an ALR anti-light screen and beautiful colors even when the lights are on.
SS_antique
The XGIMI Horizon Pro is a better projector than the Dangbei Mars Pro 4K. The Horizon Pro has a higher resolution, better contrast ratio, and more brightness.
esegan
Do not write nonsense, Dangbei Mars Pro 4K is brighter and more contrast is 1.5 times. What does higher resolution mean?
Milabobo
XGIMI Horizon Pro is 2200 ANSI lumens, Dangbei Mars Pro is 3200 ANSI lumens, how come horizon pro is brighter?
