¥599 Smart JYA lamp, a very simple aluminum rod
Stephenn
What is a nice desk lamp like? I believe that everyone will have different answers. Recently, a smart JYA lamp is very eye-catching. Let’s have a look. The smart JYA lamp iis a very simple aluminum rod, without any bending. The shell is made of aluminum alloy, which brings frosted texture through anodizing.
The weight of 1.17kg with the magnetic base on the table is also very stable.
When the Smart JYA lamp is close to the base, the base can accurately hold the bottom of the lamp. It does not need to be connected to the power supply, and the built-in 5200mAh large capacity battery can ensure that the brightest gear is always on 2.5 hours, the lowest level light state can sustain 12 hours. The Type-C charging interface is very convenient.
Different from the general table lamp, Smart JYA lamp can illuminate the desktop without bending under the cooperation of PC lens.
The dual lamp beads make it have two modes of high and low beam, among which the low beam mode has three levels of brightness and the high beam mode has two levels of brightness.
According to the official introduction, when the level 3 brightness is turned on in the low beam mode, the color rendering index can reach more than 95; the color temperature approaches 4000K of the natural light source.
Compared to the physical buttons of traditional table lamps, this product sets the light on as a virtual touch key, which is integrated to the top. You can turn on the desk lamp with a light touch. You can adjust the brightness of the light by clicking it again. Long press to turn it off.
More than that, the smart JYA lamp connected with JYA app gives more ways to play light. The touch key of the lamp body can only adjust level 5 brightness, and the app can further adjust level 100 brightness. In addition to the direct remote control of the lamp switch, you can also set the timing on, timing off and time period timing.
In addition, there are countdown reminders, which can flash after the countdown to achieve the purpose of reminders. In view of the situation that it is easy to sit for a long time in the office, the regular reminder function can be set to remind you to rest for a period of time.
Music light rhythmic mode allows the light to flash with the rhythm of the built-in music. The smart JYA lamp costs 599 yuan. Do you like it? Welcome to comment.
