BenQ projectors are often used in office, basically most companies have standard projectors. However, BenQ projectors occasionally have some problems when connecting to laptops, so what are these problems? How to solve it, I will share it with you below.
Problem 1: No output image from the projector
Method: First confirm whether the connection between the notebook and the projector is normal. If there is a problem, reconnect or replace the connection cable. If there is no problem with the connection, then the display output control on the notebook is not correct. Just press the display output control switch on the notebook to switch the mode to normal projection.
Problem 2: The projection screen is normal, but the video cannot be displayed
Method: At this time, you still need to use the display output control on the note. Switch the mode to the notebook screen is not bright, and the projector is bright to solve the problem of unable to display video.
Problem 3: The image quality of the projected image is poor
Method: This problem can be solved in two ways
1. Since the display resolution of the notebook often exceeds the resolution of the projector, the best image can be obtained by disabling the screen display of the notebook at this time;
2. Adjust the font in the projection screen and use a smooth font, because the smooth font will automatically generate a clearer font outline on the laptop and projector. The recommended font is Microsoft Plus! For Windows.
The above are the three common problems and solutions for office BenQ projectors. If there are new problems and solutions, comments are welcome.
