Xiaomi eco-chain enterprise 8HSleep Technology announced the launch of 8H adaptive soft and hard adjustable smart mattress Zero. This mattress can intelligently determine the left and right partitions, and the appropriate softness and hardness according to different posture configurations. The crowdfunding price is 4599 yuan.
The H8 smart mattress also has yoga sleep aid mode, 5 major algorithm support, Xiaoai smart voice control, independent 6-zone airbag, graphene far infrared heating and other functions.
The H8 smart mattress Zero will be launched on Xiaomi crowdfunding. According to the artificial intelligence algorithm, through the mattress built-in AI sleep system. It can automatically sense the human body data, calculate the airbag pressure value suitable for the body. The soft and hard adjustment system controls the independent 6 zones. The air volume can be adjusted in 20 seconds.
26cm thick smart mattress, 3cm thick Italian Schcott craft natural latex, with the characteristics of soft elastic and close-fitting.
The combination of independent 6-zone gas and independent pocket springs, the tough support effectively protects the spine. The skin-friendly graphene jacket fabric doubles the comfort of sleeping.
When the person is lying down, the spine curve is not completely horizontal. Under the control of the sleep system, the airbags of the shoulder, waist, and arm zones support the cervical, lumbar, and caudal vertebrae, respectively, and the air can be adjusted automatically according to the user's body shape and signs. The internal air capacity shows different softness and support.
You can also use the Mi Home APP, wireless remote control or voice control to customize the adjustment of each partition and mattress softness, no need to adjust again next time.
At the same time, the H8 smart mattress also has a sleep monitoring system, which can provide users with sleep reports.
