Artograph Junior Projector: Is tracing art a cheat or a creative boost for budding artists?
The Artograph Tracer Junior Art Projector positions itself as a solution for artists seeking to replicate and enlarge their work with ease. But is it merely a tool for convenience, or does it undermine the fundamental skills of drawing and observation that many traditional artists hold dear? In this review, we'll dive into the projector's performance, portability, and design, while questioning whether relying on technology like this enhances creativity or stifles it. With a 200mm optical glass lens promising up to 10 times enlargement, let’s explore if this device is a game-changer for artists, or just another crutch in a world increasingly reliant on shortcuts.
Spec​
Artograph Junior Projector​
ArtographJuniorProjector.jpg​
$69.99​
Enlarges flat artwork and small 3-D objects to any vertical surface
200mm optical glass lens enlarges up to 10 times original size
Lightweight, portable, silent operation
Copy size 3-Inch-by-3-Inch
5 year warranty, Made in the USA
1500 lumen​
Item Weight​
2.2 Pounds​
When I first got my hands on this projector, I was pleasantly surprised by how simple it was to set up. It came ready to use right out of the box, which is always a plus for someone like me who doesn’t have the time or patience for complicated installations. The only downside was that I had to find a way to prop it up to get the right height for projecting images onto the wall, which required a bit of creativity with books and other household items. Overall, it was a straightforward process, and I appreciated that it was portable enough to move around as needed.
As for picture quality, I found it to be decent for my needs. I was able to enlarge small sketches and project them onto walls for my art projects. The clarity was good enough to get a rough outline, though I did notice that it worked best in a dark room. At night, the images were bright and clear, which allowed me to trace without too much trouble. However, I did struggle a bit with focus adjustment—it took some trial and error to get the image just right. I wish the focusing mechanism was easier to use, as it often felt like a bit of a hassle during my creative sessions.
Other Experience​
My overall experience with this projector was a mixed bag. While I enjoyed using it for my art projects, I did encounter some challenges. For instance, the projector got a bit warm after extended use, which made me cautious about leaving it unattended, especially around kids. I also had a minor hiccup with the order process—there was some confusion with the shipping, but customer service was responsive and resolved the issue quickly. It was a relief to get the projector in time for my project, but I did feel a twinge of frustration with the initial wait.
One of the biggest pros for me was the price point. At around $39, it’s an affordable option for anyone looking to project images for art without breaking the bank. I also loved that it uses a standard fluorescent bulb, which is easier to replace and less expensive than the specialty bulbs used in other projectors. Additionally, it’s a great tool for quick projects, allowing me to create decorations and murals without the hassle of complicated setups.
On the flip side, there were a few cons that stood out to me. The main one was the size limitation of the images I could project—having to work with a small 3.5x3.5 inch area was a bit restrictive, and it required me to move the projector around quite a bit to get the whole image on the wall. I also found it necessary to have the room completely dark for the best results, which isn’t always practical. Lastly, the plastic build felt cheap, and I worried about its durability over time.
In summary, I would say this projector is a solid choice for small projects, especially for someone like me who enjoys art but doesn’t need a high-end, professional-grade tool. It gets the job done and offers good value for the price, but it does have its limitations. If you’re looking for something simple to enhance your creative process without spending a fortune, I’d recommend giving it a try. Just be prepared to work in the dark and possibly fuss a bit with the focus!
fosterzar
I got this thing thinking it’d be great for projecting some art, but man, what a letdown! The image is super fuzzy, and when I tried to zoom in, the attachment just didn't reach far enough. If it did, maybe the picture would actually look decent. Seriously, don’t waste your cash on this; go for something better. It feels more like a toy than anything! I can’t even picture a kid being able to see the image clearly enough to trace it. Total bummer!
ZacRedact
This little projector is a steal for the price! It works like a charm, but it does get a bit warm on the surface it’s on, so I’d suggest using a stand. We just propped it up on an old tile and it did the trick. My grandkids totally loved it! I got it for them as a Christmas gift for drawing book covers and doing art projects, and it was totally worth every penny. - Julia from NC
So, this whole process is pretty hands-on, and you definitely need a dark room for it. I just waited until nighttime to do my tracing.
Just remember, it’s all about getting a bit crafty—like using a rolled-up towel to lift it up on the wall so you can see better. And keep in mind, the projector only shows a 5x5 area of what you’re tracing. If your stencil is any bigger, you’ll have to tackle it in sections.
But honestly, I’m super excited about how it turned out and the price was totally worth it!
Hey, check this out! Everywhere else in Canada is charging at least 90 bucks for the same thing! I know it’s meant for kids, but trust me, it works just as well as any fancy transfer gadget out there. I use it to airbrush huge murals, and it’s been a game changer for getting those larger designs down. Pro tip: the darker the room, the better it works!
MsPippiton1117
You definitely get what you pay for with this one. It’s not total garbage, but it’s not amazing either. I tried using it to transfer a chevron design onto my wall so I could paint over it, and let me tell you, it’s a bit tricky to reposition and get that same image just right again.
