Partial sun is the most common outdoor TV install environment in the US — and the most misunderstood.
Most buyers either underbuy (a 700-nit shade-rated TV that washes out by noon) or overbuy (a $3,000 full-sun model for a patio that gets two hours of indirect afternoon light). Neither is a good outcome.
This guide cuts through it. Here's what partial sun actually means, how to tell if your patio qualifies, and the five 55-inch TVs that do it right in 2026.
A partial sun outdoor TV is designed for environments where:
The brightness requirement for partial sun is 1,000–1,500 nits. Under that, you'll wash out during peak afternoon hours. Over that, you're paying for full-sun headroom you'll rarely use.
This is worth getting right before you buy anything.
You have a full-shade install if:
You have a partial-sun install if:
You have a full-sun install if:
The most common mistake: people with pergolas assuming they're in "shade" when slatted sun is actually partial sun — and buying a 700-nit shade model that washes out every afternoon.
Partial sun is a wide category. Here's how to match nits to your actual situation:
Our blanket recommendation for most US partial-sun installs: target 1,500 nits. It's enough brightness margin for variable conditions — even if your pergola gets less light today, overage is better than underage.
1. ByteFree BF-55ODTV — Best Value with Dolby Vision
Price: $1,499–$1,599 | Brightness: 1,500 nits | Environment: Partial sun
The BF-55ODTV is built for exactly this use case. At 1,500 nits with anti-glare glass, it handles strong partial sun comfortably — the kind of setup where you're watching a 3 PM college football game under a cedar pergola while the afternoon light filters through.
The Dolby Vision support is what separates it from every other TV at this price for streaming-heavy households. Watching Netflix or Disney+ outdoors in partial sun, Dolby Vision's dynamic metadata keeps dark scenes legible and highlights punchy in ways that HDR10-only TVs can't match. There's no other 55-inch outdoor TV under $1,600 that offers this.
Other key specs: Google TV, IP55, all-metal enclosure, 30W speakers with Dolby Atmos, VESA 600×400.
Operating temp: 32°F–122°F — appropriate for southern US, coastal, and warm-climate markets.
Price: $1,599 | Brightness: 1,000 nits | Environment: Partial sun (light to moderate)
Sylvox's most popular model and the default recommendation across most installer networks. Google TV, IP55, all-metal build, 3-year warranty, and a brand track record going back further than most outdoor TV competitors.
For lighter partial-sun installs — a north-facing pergola, morning sun only, significant overhead coverage — the 1,000-nit panel holds up well. Where it struggles is strong afternoon partial sun, where independent testing has measured the panel closer to 520 nits sustained under thermal load. That's a real limitation for west-facing patios.
No Dolby Vision. HDR10 only.
Best for: Partial sun installs with less aggressive afternoon exposure, cold-climate buyers (rated to -22°F).
Price: $1,699 | Brightness: 1,000 nits | Environment: Full shade / light partial sun
SunBrite is the installer-recommended brand in the professional AV market, and the 2025 Veranda 3 update added Dolby Vision support. Android TV platform with good app coverage.
The brightness ceiling of 1,000 nits places it comfortably in light partial-sun territory but makes it marginal for heavier afternoon exposure. For buyers whose integrator or contractor specifies SunBrite, it's a solid product — but at $1,699, the ByteFree delivers more brightness and equivalent Dolby Vision support at $200 less.
Price: $4,000+ | Brightness: 2,000 nits | Environment: Partial sun to full sun
Samsung's outdoor TV flagship is unambiguously excellent — QLED panel, 2,000 nits, Tizen OS, and the Samsung ecosystem. For partial-sun installs, it's significant overkill on brightness, but delivers the best overall picture quality in outdoor conditions available today.
The price premium is real: you're spending $2,500+ more than the ByteFree for a panel that's doing more work than your partial-sun install requires. The buyers this makes sense for are luxury installs where Samsung brand and Tizen integration with other Samsung devices matter.
Price: $1,199 | Brightness: 750 nits | Environment: Light partial sun only
The most affordable option on this list. Furrion's Aurora Partial-Sun delivers IP54 weatherproofing and webOS at under $1,200. Fine for north-facing pergolas with minimal afternoon exposure or covered decks that only get morning light.
Its real limitation: 750 nits isn't enough for moderate or strong partial sun. If your pergola gets any real afternoon light — and most western or southern pergolas do — you'll find this TV washed out during peak hours.
ByteFree BF-55ODTV — 1,500 nits handles the dappled afternoon sun that comes through pergola slats. The Dolby Vision makes evening movie watching genuinely cinema-quality.
ByteFree BF-55ODTV for west-facing decks with afternoon exposure. Sylvox DeckPro 2.0+ for north/east-facing decks with minimal afternoon sun.
Element EP500AE55C ($899) — screened porches are effectively full-shade. You don't need 1,500 nits here. Save the money.
ByteFree BF-55ODTV — outdoor kitchens often face west and get afternoon light while you're actually using the kitchen. The 1,500 nits is worth it to maintain visibility during cooking hours.
ByteFree BF-55ODTV for pools with a pergola or partial shade structure. Sylvox Pool Pro 2.0+ ($2,399) for pools with no overhead cover (2,000 nits, full sun capable).
Tilt the mount for glare reduction. Most partial-sun installs benefit from a slight downward tilt (5–15°) on the wall mount. This angles the anti-glare glass away from the most direct light source and visibly improves picture contrast.
Track where the sun hits before mounting. Spend a full day noting exactly when and where direct light reaches your mounting wall. What looks "shaded" at 10 AM may get a full hour of direct western light at 5 PM.
Leave ventilation space. Don't mount flush against the wall. Outdoor TVs need airflow behind the panel for heat management — particularly important in Florida and Texas summers where ambient temperatures can push 100°F+. The ByteFree includes 4 internal cooling fans, but external airflow still matters.
Use the included weatherproof hardware. The BF-55ODTV ships with M8 screws and gaskets specifically for weatherproof mounting. Using generic hardware at outdoor connections is a common source of moisture ingress over time.
Partial sun describes an install environment where the TV receives some direct or indirect sunlight — but not full, unfiltered sun all day. Typical partial-sun environments include pergolas (slatted roofs), covered decks with open sides, and outdoor kitchens under an overhang. The key characteristic is variable light exposure — some hours shaded, some hours with meaningful ambient light. Partial-sun TVs need 1,000–1,500 nits of brightness to remain visible during brighter periods.
For most US residential partial-sun installs, 1,500 nits is the practical sweet spot. It handles the range from light filtered sun to strong afternoon ambient light. At 1,000 nits (where most $1,500-tier competitors land), visibility degrades noticeably during peak afternoon hours on moderate-to-strong partial-sun installations. Going above 1,500 nits for partial sun delivers diminishing visible returns.
Yes — a 1,500-nit TV works perfectly in full shade. You're simply running the panel with more brightness headroom than your environment requires, which has no downside other than slightly higher power draw. The reverse is not true: a shade-rated 700-nit TV will wash out visibly in partial sun.
It depends on your light exposure. For moderate to strong partial sun (most western and southern-facing pergolas, outdoor kitchens), the ByteFree BF-55ODTV at $1,499 is the strongest 55-inch option at this price — 1,500 nits and Dolby Vision. For light partial sun (north-facing pergolas, minimal afternoon exposure), the Sylvox DeckPro 2.0+ at $1,599 is a solid alternative with a longer brand track record.
The partial-sun outdoor TV market in 2026 has a gap problem: most TVs at the $1,500 price tier are rated for partial sun but equipped with 1,000-nit panels that struggle in real-world afternoon conditions.
The ByteFree BF-55ODTV fills that gap cleanly — 1,500 nits at $1,499 is a spec previously unavailable below $2,000. For the majority of US homeowners with a pergola, covered deck, or outdoor kitchen in a warm-climate market, it's the practical answer.
Match the TV to your actual exposure level, not to what "partial sun" sounds like in the abstract. If you're not sure, measure: sit outside at your mounting location at 2 PM on a sunny day. If you're squinting, buy 1,500 nits. If it's genuinely shaded, 1,000 is fine.
Related reading:
What Is a Partial Sun Outdoor TV?
- Direct sunlight sometimes hits the screen (but not all day)
- More often, the screen sees indirect or ambient bright light
- The install is neither fully sheltered nor fully exposed
How to Identify Your Patio Type
- The patio has a solid roof (not slatted)
- No direct sun reaches the wall where the TV will mount — at any time of year
- It's an enclosed screened porch, a roofed covered porch, or a carport
- Your pergola has slatted or lattice roof (sun filters through)
- Your patio has a solid overhang but open sides and you get afternoon light
- The TV gets direct sun for 1–3 hours daily but not all day
- Your outdoor kitchen faces west and gets afternoon light
- The TV faces south or west with no overhead cover
- Direct sun hits the screen for 4+ hours during the day
- You're mounting on an exposed pool deck or rooftop
Brightness Requirements for Partial Sun
| Light level | Typical scenario | Minimum nits needed |
| Low partial sun | Pergola facing north, morning light only | 1,000 nits |
| Moderate partial sun | Cedar pergola with afternoon dapple | 1,000–1,200 nits |
| Strong partial sun | West-facing covered deck, significant afternoon light | 1,500 nits |
| Near full sun | Minimal overhang, several hours of near-direct light | 1,500–2,000 nits |
Top 5 Partial Sun 55" Outdoor TVs in 2026
2. Sylvox DeckPro 2.0+ — Reliable Partial Sun Pick
3. SunBrite Veranda 3 — Best Brand Recognition
4. Samsung The Terrace LST7D — Best Premium Option
5. Furrion Aurora Partial-Sun — Budget Partial Sun
Best Outdoor TVs by Specific Patio Type
Best for Pergolas
Best for Covered Decks (with open sides)
Best for Screened Porches
Best for Outdoor Kitchens
Best for Poolside (partial shade)
Installation Tips for Partial Sun Setups
Frequently Asked Questions
Q: What does partial sun mean for an outdoor TV?
Q: How many nits do I need for a partial sun patio?
Q: Can I use a partial sun TV in full shade?
Q: What's the best 55-inch outdoor TV for a covered patio?
Verdict
Related reading:
