Best Outdoor TV Cover in 2026: How to Protect Your TV
liliya
Even IP55-rated outdoor TVs benefit from a quality cover during off-season storage and extended non-use periods. The cover doesn't replace the TV's built-in weatherproofing — it adds an extra protective layer that meaningfully extends panel and electronics lifespan, especially in coastal and high-UV climates.
But not all outdoor TV covers are equal, and the wrong cover can actually accelerate damage. Here's what to look for, the mistakes that ruin protection, and the covers actually worth buying for 2026.
Why Buy an Outdoor TV Cover If My TV Is Already IP55?​
Three reasons IP55-rated outdoor TVs still benefit from covers:
1. UV degradation accumulates over years. Sun exposure breaks down rubber gaskets, plastic bezels, and panel coatings over 5-10 years even on outdoor-rated TVs. A cover during multi-month non-use periods (winter storage, extended vacations) can extend panel life by 1-3 years. Especially relevant in Arizona, Texas, Florida, and California.
2. Salt air corrodes faster than weatherproofing handles. Coastal installations within 5 miles of saltwater see accelerated corrosion of metal bezels, fasteners, and exposed connectors. IP55 prevents water intrusion but doesn't address salt-induced electrochemistry. A cover during storms or extended salt-air exposure adds a barrier the TV's seals can't provide.
3. Cumulative humidity affects internal electronics over time. IP55 prevents acute water damage but humid climates (Florida, Gulf Coast, Pacific Northwest) cycle through condensation conditions daily. A cover during multi-day rain events or extended off-season periods reduces cumulative humidity exposure.
The math: $40-$80 cover, applied during 3-4 months of off-season annually, adds 1-3 years to typical TV lifespan. Net cost-benefit is strongly positive for any TV in coastal, high-UV, or seasonal-use climates.
What to Look for in an Outdoor TV Cover​
Material​
Heavy-duty polyester or marine-grade vinyl are the right materials for outdoor TV covers:
  • 600D polyester (industry standard for outdoor protection)
  • Marine-grade vinyl (more weather-resistant, slightly more expensive)
  • Avoid: cheap nylon, lightweight cotton-blend, "weatherproof" fabric without specific weather rating
Fit​
Snug but not tight. Covers should fit the TV's specific dimensions without excess slack (which lets wind catch and damage the TV) or constraint (which can put pressure on bezels and edges).
Pre-sized covers for 55-inch TVs typically fit dimensions of 49-52 inches wide × 28-32 inches tall, with depth allowance for the TV's mounting profile. Verify your specific TV's dimensions before purchase.
Drainage​
Ventilation grommets at the bottom are critical. Covers without drainage trap moisture — exactly the opposite of what you want. Look for at least 4 grommets along the bottom edge of the cover.
Securing​
Multiple straps with metal buckles, not Velcro. Velcro fails quickly in outdoor conditions due to UV degradation and dirt accumulation. Wind-rated covers use:
  • 4-6 secure straps with metal hardware
  • Bottom drawstring for snug fit
  • Side ties to prevent wind lift
UV Resistance​
UV-stabilized fabric specifically. Standard polyester degrades within 1-2 seasons in direct sun exposure. UV-stabilized variants last 5+ years. The cover protecting your TV shouldn't itself need annual replacement.
Top 5 Outdoor TV Covers for 2026​
1. KHOMO GEAR PANTHER 55" Cover ($45-$55) — Best Value Overall​
Material: 600D polyester with PVC backing Fit: Specifically sized for 55-inch outdoor TVs (works on most 50-58" diagonals) Drainage: 6 ventilation grommets along bottom UV resistance: UV-stabilized for 5+ year exposure Securing: 4 straps with metal buckles, bottom drawstring
The most-reviewed outdoor TV cover on Amazon with consistent positive feedback over multiple years. Solid construction, fits a wide range of 55-inch TVs, and the price-to-quality ratio is genuinely strong.
Best for: Most 55-inch outdoor TV installations needing reliable seasonal protection.
2. Premium Outdoor TV Cover by NEXT (Custom Sizes, $65-$125)​
Material: Marine-grade vinyl Fit: Custom sizing per TV model Drainage: Multiple ventilation points + zippered bottom UV resistance: Marine-grade UV stabilization (boat industry standard) Securing: 6 straps with locking metal hardware
The premium tier. Marine-grade construction is meaningfully more durable than budget polyester options. Custom sizing eliminates the "almost fits" problem common with universal covers. Higher price, but appropriate for premium TV investments ($2,000+ TVs).
Best for: Premium outdoor TVs (Samsung Terrace, SunBrite Cinema), coastal installations with severe weather, buyers prioritizing maximum durability.
3. Ben Pier Outdoor TV Cover ($35-$45) — Best Budget Pick​
Material: Standard 420D polyester Fit: Universal size for 55-65" TVs Drainage: 4 ventilation grommets UV resistance: Basic UV protection Securing: 3 Velcro straps + drawstring
The legitimate budget option. Adequate for indoor storage during winter or short-term outdoor cover for moderate climates. Velcro straps are the main compromise — they degrade in extreme weather but work for 1-2 seasons.
Best for: Tight budgets, mild climates, indoor storage covers, secondary outdoor TVs.
4. Khomo Premium 55" Black Cover ($75-$95)​
Material: 600D polyester with reinforced corners Fit: Specifically sized for outdoor mounted 55-inch TVs Drainage: Dual-zip access plus 4 grommets UV resistance: Premium UV stabilization Securing: 6 elastic-and-metal strap system
The mid-premium option. Reinforced corners specifically designed for outdoor TV mounting points (the most stress-prone areas). Dual-zip access lets you reach connections without removing the cover entirely — useful for occasional winter checks.
Best for: Permanently mounted TVs that need easy seasonal access, 55-inch wall-mounted installations.
5. The TV Shield Pro Pack ($150-$200) — Best Permanent Solution​
Material: Aluminum housing + polycarbonate front Fit: Custom-fitted enclosure for specific TV size (not a soft cover) Drainage: Built-in ventilation system with cooling fans UV resistance: Aluminum housing (maximum durability) Securing: Permanent bolted enclosure
Technically not a cover — it's a permanent enclosure that lets you mount a regular indoor TV outdoors with maximum protection. For buyers who want indoor TV picture quality with outdoor durability, this is the right path. Significantly more expensive but lasts decades.
Best for: Indoor TVs being adapted for outdoor use, permanent installations where the TV is not removed seasonally, buyers wanting maximum protection for premium TVs.
3 Common Mistakes That Ruin Outdoor TV Cover Protection​
Mistake #1: Putting the cover on a hot TV​
Covers trap heat. Putting a cover on a TV that's been running in direct sun and is still warm creates condensation as the TV cools. Moisture gets trapped between the TV and cover surface — exactly the opposite of what you want.
Fix: Always cover the TV at least 2 hours after powering off, ideally in the evening when temperatures have dropped.
Mistake #2: Covering a TV without drainage grommets​
Inexpensive covers without bottom drainage trap rainwater that seeps in around the edges or condensation that forms inside the cover. Trapped water sits against the TV for days or weeks during off-season storage — causing exactly the moisture damage the cover was supposed to prevent.
Fix: Buy only covers with at least 4 ventilation grommets at the bottom edge. Inspect grommets seasonally for blockage.
Mistake #3: Using a cover that doesn't fit properly​
Too-loose covers let wind catch the cover, repeatedly stressing the mounting straps until they fail or the cover blows off. Too-tight covers put pressure on bezels and edges, particularly damaging mounting points over time.
Fix: Measure your TV's exact dimensions (not just the diagonal) before purchasing. Most covers list specific size ranges they fit. Avoid "universal" covers with broad size ranges (40-65" etc.) — they fit nothing perfectly.
When NOT to Use an Outdoor TV Cover​
Covers aren't always appropriate:
During hot weather active use periods. Don't cover a TV that's being used regularly in summer. Daily on/off cover application is impractical and creates more wear on cover hardware than it prevents on the TV.
In high-wind storm conditions if not properly secured. A loose cover during a thunderstorm can damage the TV more than rain alone. If you can't properly secure the cover before a storm, leave it off.
For continuous year-round use without removal. Permanent covers create cumulative humidity issues. Even fitted covers need monthly removal during use seasons to let the TV breathe.
On already-damaged TVs. A cover doesn't fix existing weatherproofing failures. If your TV has condensation inside the screen, gasket damage, or visible corrosion, address those first.
Cover Care and Maintenance​
To maximize cover lifespan:
  • Annual cleaning with mild soap and water, fully air-dried before next use
  • Annual inspection of straps, grommets, and seams for wear
  • Indoor storage of the cover itself during peak active TV use season (covers stored outdoors degrade faster than covers used seasonally)
  • Replace damaged covers immediately — a compromised cover provides false security
A quality cover used correctly should last 5+ years. A budget cover treated carefully should last 2-3 seasons.
Frequently Asked Questions​
Q: Do I need a cover for my outdoor TV?​
If your outdoor TV is IP55-rated and used regularly year-round, a cover is optional but beneficial during off-season storage (winter), extended vacations, or high-UV summer periods. For coastal installations within 5 miles of saltwater, a cover is strongly recommended even with IP55 rating. The $40-$80 cost extends typical TV lifespan by 1-3 years.
Q: What size cover do I need for a 55-inch outdoor TV?​
Most 55-inch outdoor TVs measure approximately 49" wide × 28" tall × 4" deep. Covers labeled "55-inch outdoor TV cover" generally fit this range, but verify your specific TV's dimensions before purchase. Avoid universal covers labeled for ranges like "40-65 inches" — they don't fit any size properly.
Q: Are outdoor TV covers waterproof?​
Quality outdoor TV covers are water-resistant rather than fully waterproof — they shed rain effectively but include drainage grommets to prevent moisture trapping. Truly waterproof covers (no drainage) cause more damage than they prevent because trapped condensation has nowhere to escape. Look for water-resistant covers with proper ventilation rather than fully waterproof construction.
Q: Can I leave my outdoor TV uncovered all year?​
Yes, if it's IP55-rated and you live in a moderate climate without extreme UV or salt air exposure. Your TV will likely last 5-7 years uncovered vs 7-10 years with seasonal covering. Covers are particularly valuable during multi-month non-use periods and in harsh climate conditions (coastal, desert, tropical).
Q: How much should I spend on an outdoor TV cover?​
Budget $40-$80 for a quality cover on a $1,500 TV (KHOMO GEAR or similar mid-tier). For premium TVs ($2,000+), step up to $80-$125 for marine-grade construction. Spending under $30 typically means quality compromises (Velcro instead of metal buckles, no UV stabilization, poor drainage) that defeat the purpose. Spending over $150 makes sense only for permanent enclosures or custom-fitted covers for unusual TV configurations.
Verdict​
A quality outdoor TV cover is one of the highest-ROI accessories for any outdoor TV install. $40-$80 of cover cost extends a $1,500 TV's lifespan by years — particularly in coastal, high-UV, or seasonal-use climates.
For most residential 55-inch outdoor TVs in 2026, the KHOMO GEAR PANTHER 55" Cover ($45-$55) is the right balance of quality and price. Adequate construction, proper drainage, UV stabilization, and reliable strap securing for a fraction of premium options.
The mistakes to avoid:
  • Don't cover a hot TV (let it cool 2+ hours first)
  • Don't buy covers without drainage grommets
  • Don't buy "universal size" covers — get fit-specific covers
  • Don't use covers during active use seasons (only during extended off periods)
The cover doesn't replace the TV's built-in IP55 weatherproofing. It supplements it for the periods when extra protection genuinely matters.
Related reading:
