Dramaqueen
Q: X96 max+ box automatic shutdown when using, how to fix it?
A: X96max box is famous not only for its powerful function, but also for its heating problem. It is estimated that the heat is turned off due to excessive heat. This box is not well-known for its good heat dissipation. It will be modified by yourself. See the sharing post . If you do n’t want to do it, you can directly add a cooling fan base under it.
1. Restore the factory or flash a new system,
2. See if it is automatically shut down as long as you run a certain software, if not it may be caused by high temperature
