How can Fire TV cube screenshot?
Ping
I bought a fire tv cube from Amazon and I really want to share the screenshot with my friends. How can I do that? I h
RickyT
Generally speaking, Amazon Fire TV can use the buttons of the remote control to take screenshots. With the device turned on, press and hold the volume down button and the power button at the same time for one second. The screen will flicker briefly, and a smaller screen image will appear in the center of the screen, indicating that the screen capture is successful.
LLLisa
You can get Easy Fire Tools from the Google Play Store. Install it on your Android phone. Enable your Fire TV cube ADB and then connect it to your Cube. It has a screenshot option, and then you can save it to your phone.
Graceli
There is how to take screenshots on Fire TV cube, hope it will help you!
