If you want to use the TV screen as the monitor of the computer, the TV needs to have the corresponding video input interface (including the mainstream HDMI interface and DP interface). The following takes Windows 10 system computer as an example to illustrate the specific operation method:
1. Use a video data line (HDMI data line or DP data line, depending on the actual situation) to connect to the computer video output interface and TV video input interface.
2. In the navigation bar at the bottom of the computer, click the Windows logo to enter the start menu, and click the gear icon button to enter the Windows system settings.
3. Click the [System] option in the system settings, click the [Display] option in the list on the left, and select the TV screen as the main display in the [Multi-Monitor Settings] on the right.
4. If you need to use the computer and TV screen at the same time, you can modify the multi-monitor setting to [Extend the desktop to this monitor].
