Want to watch your favorite Hulu shows on the big screen? Whether you're planning to binge The Bear or catch live sports, this guide will walk you through how to get Hulu on your smart TV, regardless of brand.
This article covers Samsung, LG, Vizio, Sony, Hisense, Roku TV, Android TV, and more. We’ll also cover alternative methods in case your TV doesn’t support the Hulu app.
Before downloading Hulu, make sure your TV meets these conditions:
You’ll also need a Hulu subscription. Plans start at $7.99/month (with ads).
If Hulu isn’t available on your TV, don’t worry. Try these workarounds:
Plug in any of the following into your HDMI port:
These devices support Hulu natively.
No, Hulu requires a subscription. However, the app is free to download, and some new TVs come with a free trial.
Only if you want access to live sports, news, and local channels. Otherwise, the basic Hulu plan includes on-demand shows and movies.
Getting Hulu on your smart TV is quick and easy—especially with newer models. If your TV doesn’t support the app, using a streaming stick or casting from your phone is a reliable workaround. Either way, Hulu makes it easy to access high-quality entertainment on the big screen.
Related Reading:
Hulu not working on Vizio smart TV, how to fix?
Is Your Smart TV Compatible with Hulu?
- The TV is connected to the internet (Wi-Fi or Ethernet).
- Your smart TV model is from 2016 or newer (older models may not support Hulu).
- The Hulu app is available in your country.
How to Install Hulu on Smart TV (Step-by-Step)
For Samsung Smart TVs (Tizen OS, 2016+)
- Press the Home button on your remote.
- Navigate to Apps.
- Select the Search icon, then type “Hulu.”
- Select the Hulu app and click Install.
- Open the app, log in with your Hulu credentials, and start watching.
For LG Smart TVs (webOS)
- Press the Home button on your LG remote.
- Open the LG Content Store.
- Use the search bar to look for “Hulu”.
- Select the app, click Install, then open it and log in.
For Vizio SmartCast TVs
- Newer Vizio TVs (SmartCast 2016+) come with Hulu preinstalled.
- Press the V button or Input → select Hulu from the app row.
- If it's not showing, cast from your phone using AirPlay or Chromecast.
For Android TV / Google TV
- Open the Google Play Store from the Home screen.
- Search for Hulu.
- Select and Install the app.
- Open the app, sign in, and start streaming.
For Roku TVs
- Press the Home button.
- Go to Streaming Channels > Search Channels.
- Type Hulu.
- Select Add Channel, then launch it.
- Sign in to your account.
Can’t Find the Hulu App on Your TV?
1. Use a Streaming Device:
- Roku Stick
- Amazon Fire TV Stick
- Apple TV
- Google Chromecast with Google TV
2. Screen Cast or AirPlay from a Phone:
- iPhone/iPad: Use AirPlay to cast Hulu to a compatible smart TV.
- Android: Use Google Cast or Miracast to mirror your screen.
FAQ
Is Hulu free on Smart TVs?
Do I need Hulu + Live TV?
What internet speed do I need?
- 3 Mbps for on-demand
- 8 Mbps for live TV
- 16 Mbps for 4K Ultra HD
Final Thoughts
Related Reading:
