This article will introduce the solution on how to reset Hisense TV no picture.
There are many reasons why your Smart TV is not outputting pictures. First, a software update may have failed or it may simply be a bug. Performing certain operations while using the TV may cause the display to go black. Sometimes it may also be caused by a hardware failure. But to determine the real cause, it is better to perform a factory reset. Only on this basis, it is possible to understand the nature of the problem. Therefore, please follow the below methods to solve how to restart Hisense Smart TV without pictures.
Since you can't tell if the problem is hardware or software just by looking at the TV screen, you'll need to do a factory reset. You can reset a Hisense Smart TV with no image in the following two ways.
Most Hisense TVs also have a simple and small reset button, usually located on the back. It will appear in the section where you have TV input and output ports.
There is a reset button on the back of the Hisense TV. To restart the Hisense TV, simply press and hold the reset button for about 15 seconds. The TV should restart automatically. This is when you leave the reset button. If you see an image on your TV, a reset can help fix it.
1. First, if you haven't turned off the TV, you need to turn it off.
2. Once this is done, you will need to disconnect all connected devices from the TV. The device in question can be any USB, set-top box, network cable, etc.
3. Now you need to disconnect the TV from the power supply.
4. Unplug the TV for at least 2 minutes.
5. This is a soft reset that you perform as it deletes everything currently present in the TV RAM.
6. When the time runs out, just connect the TV box to the power supply and turn it on.
7. If the problem is only with the software, the TV should return to normal display.
If your Hisense Roku TV doesn't display an image, you can perform a reset using a simple and convenient button combination.
1. First, you need to turn on the Hisense Roku TV. Use the remote to turn it on.
2. Now, use the remote control to press the up navigation key once.
3. You must press the rewind button twice.
4. Finally, click the "Forward" button twice.
5. Usually, if your TV is displaying an image, it will freeze for a while at first and then display a black screen.
6. The TV should restart automatically shortly thereafter.
7. In this case, if your TV can display the image normally after pressing the above button, the problem is solved.
If you have any questions about installing and downloading apps on Hisense Smart TVs, you can leave a message in the comment section below.
Why does Hisense TV have no picture?
How to reset Hisense TV with No Picture?
Method 1: Reset Hisense TV with the reset button
Method 2: Replug Hisense TV from the power source
Method 3: Reset Hisense Roku TV with Remote Buttons
Summary
These are the three methods to reset on Hisense Smart TV. If none of these methods solve the problem, the best thing to do is to bring it to a service center and have it checked by an authorized person.If you have any questions about installing and downloading apps on Hisense Smart TVs, you can leave a message in the comment section below.
