Many people are curious about the difference between Huawei Smart Screen S86 Pro and Huawei V series? Let's take a look.
Huawei Smart Screen S86 Pro and Huawei Smart Screen V series are basically the same in frame and base configuration, but different in camera configuration.
The Huawei Smart Screen S86 Pro uses an external camera with 13 million AI eyes. The Huawei Smart Screen V series has a built-in camera with 24 million AI eyes.
I personally think that the camera settings of Huawei Smart Screen S86 Pro will be more convenient to take, but the camera configuration of Huawei Smart Screen V series is higher.
There is no difference between Huawei Smart Screen S86 Pro and Huawei Smart Screen V series in terms of screen display technology, and the two are basically the same in terms of color gamut.
However, the brightness of Huawei Smart Screen S86 Pro is 300-500 nits, and the Huawei Smart Screen V series is 500-800 nits. The brightness of the Huawei Smart Screen V series is higher than that of the Huawei Smart Screen S86 Pro.
The sound effect of Huawei Smart Screen S86 Pro will adopt the Dolby & DTS dual decoding mode, which makes the overall sound effect more three-dimensional and surround, and can also enhance the authenticity. Huawei's smart screen V series uses Dolby Atmos, plus Tiare audio.
In general, with the addition of French audio, the sound quality of Huawei Smart Screen V series has been better improved. Therefore, the sound quality of Huawei Smart Screen V series is much better than Huawei Smart Screen S86 Pro.
The memory of Huawei Smart Screen S86 Pro will probably be set at 32GB+3GB, while Huawei Smart Screen V series will be 64GB+4GB. Therefore, the memory of Huawei Smart Screen V series is much larger than Huawei Smart Screen S86 Pro. In terms of CPU, Huawei Smart Screen S86 Pro and Huawei Smart Screen V series are the same, both are dual-core A53 + dual-core A73.
In terms of interface, Huawei Smart Screen S86 Pro and Huawei Smart Screen V series are also the same.
1. Appearance
2. Picture quality
3. Sound effects
4. Hardware configuration
