Is a 55-inch TV considered big?
Barton7
A 55 inch TV was considered big before, but since there's a huger TV size like 80 inch, the 55 inch TV seems to be small now. However, you need to know if the TV size can fit the space of your room. You may be confused about the dimension of a 55-inch TV, so you can use this TV Size Calculator to calculate before your purchase in case you choose an unperfect size.
TV Size Calculator
And there are the common size TV demensions.
Bruce33
wow this is a really useful tool
