Gabe
Difference between Dangbei X3 and JMGO X3
1. Differences in optical parameters
First of all, there is a big difference between JMGO X3 and Dangbei X3 on the light source. Dangbei X3 uses ALPD laser light source technology, JMGO X3 is still an LED light source, and the light source difference also makes Dangbei X3 brightness up to 3200ANSI lumens, while JMGO X3 only 1500ANSI lumens. In addition, JMGO X3 and Dangbei X3 have different resolution, both are equipped with a built-in 0.47DMD display chip, JMGO X3 uses XPR chip shake technology, resolution reached 4K.
2. Differences in system parameters
In terms of system, Dangbei X3 is Dangbei OS, JMGO X3 is JMGO, the built-in film and television resources of Dangbei OS is more rich. In terms of hardware configuration, Dangbei X3 uses the latest high-end mediatech chip, MTK9669, with a combination of 3+64GB memory, while JMGO X3 uses Mstar6A838 chip, with only 2+16GB memory. The hardware configuration of Dangbei X3 is much stronger.
3. Projection performance difference
JMGO X3 and Dangbei X3 are different in performance. Due to the advantages of Dangbei X3's hardware configuration and processing chip, it can support laser non-inductive focusing and automatic trapezoidal correction. And it has AI automatic dimming, intelligent obstacle avoidance, automatic screen entry and remote control retrieve and other features. JMGO X3 focusing efficiency will be much slower, trapezoidal correction also needs manual adjustment, not to support automatic screen entry, remote control retrieve and other functions.
