LG 24LH4830-PU 24-Inch Smart TV Review
If you are looking for a cheap small LED TV, look at here. The LG 24LH4830-PU 24-Inch Smart TV maybe a good choice if you only watch videos from the in-built playsources. Here is my review on the LG 24-inch smart TV.
LG 24LH4830-PU 24-Inch Smart TV Specifications:
Model number: 24LH4830-PU
Resolution: HD 1366 x 768p
Backlight Technology: LED
Connectivity: Miracast & WiDi, HDMI,Bluetooth
Viewing angle: 178 degrees
Sound System: Virtual Surround
RMS Output Power: 10 W
Video Signal Standard: HDTV
Batteries: 2 AAA batteries required
Weight: 7.5 lbs
HDMI ports: 2
Model year: 2016
LG 24LH4830-PU 24-Inch Smart TV pros:
1. Light weight. Easy setup.
2. Good picture quality.
3. It can access to Netflix.
4. Perfect size for small rooms and spaces.
5. Cheap price.
LG 24LH4830-PU 24-Inch Smart TV cons:
1. Sound volume is a little bit low.
2. No 3.5mm earphone output. No usb port.
3. There are some useless apps. You can't add or remove apps.
4. I couldn't get the Netflix and YouTube cast to connect from my phone to the TV.
