LG HU70LS projector uses advanced 4CH LED light source technology
reality
LG launched a high-end home 4 k projector in Japan, according to introducing, LG HU70LS resolution is 4k, using the LG advanced 4CH LED light source technology, LG HU70LS support HDR and TruMotion technology at the same time, have relatively rich color and flow dynamic images, launched in Japan projection market caught the attention of a lot of projection lovers.
LG HU70LS
The LG HU70LS USES a traditional projection scheme, rather than a short-focus projector, with an all-white color scheme and a large number of air vents on both sides. It measures 314x210x100 and weighs about 3.2kg. Based on the Texas instruments DLP + DMD chip scheme, it can project at a resolution of 3840 x 2160, support a 1.25x zoom, and project a maximum of 140-inch painting. The biggest highlight of LG HU70LS is the use of LG 4ch LED light source technology, which actually has four independent color sources of RGBB. Compared with the traditional projection, the color can be restored to the maximum, with a contrast of up to 150000:1, and the color reduction is more natural and accurate, which can also reduce the color overflow problem. However, the brightness is only 1500 lumens, it is recommended to do a good job of shading, work in the scene with weak ambient light.
LG HU70LS
In addition, it supports bluetooth and wireless screen projection (a special program for LG TV Plus), as well as HDR 10 and TruMotion dynamic acceleration technology, which ensures excellent color and smoother dynamic picture. The built-in LED light source promises 30,000 hours of trouble-free operation life, which is calculated as 8 hours of viewing time per day, which is enough for the average family to use for 10 years.
The built-in remote has backlit buttons that officials say are "magic to control" and are easy to control in low-light or dark environments. In addition, two 3W speakers are integrated to support dual-frequency wireless connectivity, and tail extensions include: 2 USB 2.0, 1 usb-c (DP supported), dual HDMI, S/PDIF fiber audio, gigabit LAN, and power supply interfaces.
