8GB is the number, and on Samsung sets the system files alone can take up to 20 percent of it. That is the whole reason your three year old TV feels slower than the stick you paid forty quid for, and it is not something a settings menu is going to fix.
The maths gets worse from there. Manufacturers preload streaming apps at the factory, most of which you will never open, and several of those cannot be uninstalled at all depending on the brand. Then every app you actually use builds a cache - Netflix keeping thumbnails so it does not redownload them, and so on for everything else. None of that is unreasonable behaviour on its own. It is unreasonable when the budget is 8GB and a fifth of it is gone before you have installed anything.
What you can actually do: clear app caches in settings, which is safe and does not remove the app, and it will rebuild over the following weeks. Uninstall anything you have not opened in three months. That is the whole toolkit, and it is a holding action rather than a fix.
The honest answer is what most of us here already did, which is to stop asking the TV to be a computer. A separate streamer brings its own storage, its own OS, and gets replaced for less than a hundred when it slows down, while the panel carries on being a panel for another eight years.
Has anyone actually seen a set ship with meaningfully more than 8GB? I would like to know which brand is bothering.
