XXMAN98
- 1 1. Size
- 2 2. Brightness
- 3 3. Display
- 4 4. Chip
- 5 5. Storage
- 6 6. Speaker
- 7 7. Connectivity
A few days ago, OPPO released a new TV OPPO K9x 65 inches, many people are curious what the difference between OPPO K9x and the previous old OPPO K9, and this article will tell you.
OPPO TV K9x is only available in the 65-inch version, while OPPO TV K9 is relatively richer in size segment, covering four sizes of 43-inch/55-inch/65-inch and 75-inch, which can meet the different needs of users.
OPPO TV K9x's typical brightness is 280nits, but 55 inch / 65 inch and 75-inch OPPO K9's typical brightness is 300nits, it is worth noting that 43-inch OPPO TV K9's typical brightness is 220nits.
Overall, the display of the OPPO K9 TV will be better than the OPPO K9x. OPPO K9x TV color gamut value is 70% NTSC, although it supports HDR10+/HDR10/HLG display, it is not certified by HDR. The OPPO TV K9 has passed HDR10+ certification and has a color gamut value of 93% DCI-P3, except for the 43-inch OPPO TV K9.
OPPO K9x and 43-inch OPPO K9 with quad-core A53 CPU, K9 with quad-core A73 CPU, in terms of chip performance, 55-inch/65-inch and 75-inch OPPO TV K9 will be stronger than OPPO TV K9x.
OPPO TV K9x storage is 2GB+16GB, while the 75-inch OPPO TV K9 has 2GB+32GB of storage.
OPPO TV K9x is 20W audio power, and OPPO TV K9 reaches 30W audio power, which also means that PPO TV K9 will perform better in terms of sound effects.
OPPO TV K9 is equipped with 1 more HDMI 2.0 port than OPPO TV K9x, and the playability has been improved.
Overall, OPPO TV K9x is a TV product that focuses on large screen and cost performance, while OPPO TV K9 will be stronger in terms of sound and picture performance. Users can choose the product more suitable for them according to their needs.
1. Size
2. Brightness
3. Display
4. Chip
5. Storage
6. Speaker
7. Connectivity
