Optoma vs HIPPUS: Which Projector Delivers Superior Brightness and Smart Features for Outdoor Movies?
  1. 1 Specs
  2. 2 Which to get
In today’s comparison, we’re diving into two starkly different approaches to projection: the Optoma Laser/Phosphor DLP Projector versus the HIPPUS Mini Outdoor Projector.
On one hand, we have the Optoma, designed for those who prefer a more traditional setup with multiple projection methods—ceiling, front, and rear. It’s a powerhouse intended for fixed installations, catering to a dedicated home theater experience. But is its fixed nature limiting in a world that values versatility?
On the other hand, the HIPPUS Mini Outdoor Projector is a compact marvel, complete with Android 11.0, boasting a mere 1.17 pounds of weight and the ability to project anywhere, anytime. With upgraded brightness and smart capabilities, it seems perfect for spontaneous movie nights under the stars. But can such portability compromise image quality and viewing experience compared to a more established projector like the Optoma?
Let’s unpack the pros and cons of each, evaluating whether the convenience of the HIPPUS truly stands up to the performance pedigree of the Optoma.
Specs​
Optoma Laser/Phosphor DLP Projector​
HIPPUS Mini Outdoor Projector​
OptomaLaser_PhosphorDLPProjector.jpg​
HIPPUSMiniOutdoorProjector.jpg​
$2825.21​
$79.99​
Indoor/Outdoor​
Projection Method: Ceiling
Projection Method: Front
Projection Method: Rear
【Smart Projector with Android 11.0】The product has built-in Android 11.0 and is easy to operate. It comes pre-installed with multiple APPS and supports downloading APPS. No TV stick is required. Just connect to WiFi, log in to your account, and start movie night anytime, anywhere.
【Upgraded 350ANSI, Super Mini】HY300 Pro has upgraded the product brightness, up to 350ANSI, making the overall picture clearer and brighter. Its super mini portable design allows it to be held in one hand and weighs only 1.17 pounds, making it easy to carry and use outdoors.
【Automatic vertical correction and 4D electronic correction】The projector is designed to rotate (180°), supports multi-angle projection images, 3s automatic vertical image correc
1080 Hz - 102 Inches​
40 Inches - 130 Inches​
1.3 Feet - 13.13 Feet​
0.65 Feet - 9.8 Feet​
1000000:1​
1080 Hz​
4K Pixels​
1280 x 720​
4000 Lumen​
2450 lumen​
DLP​
Short Throw​
Speakers​
H.264 or H.265​
125 Watts​
15000 Hours​
Button Control​
Button Control​
Touch​
VGA, HDMI​
Wireless​
Laptop, Smartphone, Gaming Console​
125 watts​
Mount Type​
Ceiling Mount​
Tabletop Mount​
7.8"L x 4.69"W x 5.28"H​
Which to get​
Looking to get a new projector and I'm torn between two options: the Optoma Laser/Phosphor DLP Projector and the HIPPUS Mini Outdoor Projector.
The Optoma sounds like it has solid projection capabilities with multiple methods (ceiling, front, rear), which is great for versatility. But I’m curious about the picture quality and sound. How does it stack up for home theater use? Any potential downsides I should be aware of, like installation complexity or noise levels?
On the other hand, the HIPPUS is super portable and comes with Android 11.0, which is a huge plus for streaming without extra devices. The 350ANSI brightness sounds decent, but I wonder how it performs in different lighting conditions. Is the sound quality good enough for outdoor viewing? And does the automatic image correction really work well?
I'd love to hear your thoughts on picture and sound quality, ease of use, and any drawbacks you’ve encountered with either option! Thanks!
