GOWE vs SkyEcho: Which Mini Projector Delivers Superior Portability and Smart Features for Outdoor Entertainment?
shootamcg
  1. 1 Specs
  2. 2 Which to get
In a world where entertainment on the go is becoming the norm, two pocket projectors vie for your attention. On one side, we have the GOWE Mini Pocket Projector, boasting a native resolution of 1280x800 and a brightness rating that might just make it a viable option for more intimate settings. Its 360-degree image flip and an extensive range of connectivity options provide flexibility, while a focus on LED longevity speaks to its durability.
On the other hand, the SkyEcho Portable Outdoor Projector raises the stakes with its promise of 4K video decoding and an auto-focus feature that aims for hassle-free setup. Not to mention, its adjustable stand claims to ensure optimal viewing angles whether you're indoors or out.
But with different strengths and weaknesses, which projector truly deserves your investment? Does the GOWE's comprehensive feature set outweigh the SkyEcho's higher resolution and convenience? Let's dig into the details and find out which of these mini projectors stands out in the great outdoors and beyond.
Specs​
GOWE Mini Pocket Projector Projector​
SkyEcho Portable Outdoor Projector​
$59.99​
Home Cinema​
Projector​
Projector system :DLP; Native resolution:1280X800; Brightness:500(ISO); Contrast:10000:1 Image reverse: 360 degree flip ; Lens : Manual Focus , Color : 16.7 million Full color; Scale ratio: native 16:10 , support 4:3 ; Lamps type : LED RGB,¡Ý30000h ;
Pictures size : 20-115 inch; Keystone : ¡À40 degree; Interface input: HDMI*2/PC-RGB/Av/Usb/Audio Out /Micro- SD/Micro-USB ; Android 4.0 system: NO; 3D: YES; Power consumption : total 50W; Voltage: 19V; N.W. : 0. 445 KGS , G..W.:0.5KGS
Auto Focus & Keystone Correction: Supports automatic focus and vertical keystone adjustment; 【 Manual adjustment required for horizontal alignment 】
Adjustable Stand: Features an integrated projector stand with multi-angle adjustment for projection on any surface from floor to ceiling
4K Video Decoding: Supports up to 4K video decoding for superior picture quality with vibrant colors
N/A - 1.5E+2 Inches​
0.95 - 4 Meters​
10000:1​
Good​
1280 x 720 Pixels​
1280 x 720​
DLP​
Portable​
Auto Focus​
HEVC​
20000 Hours​
Button Control​
Button Control​
Wi-Fi​
Laptop, Gaming Console, Television, Smartphone, Speaker​
50 watts​
Mount Type​
Tabletop Mount​
Tripod Mount​
Which to get​
I'm torn between two projectors and could really use your help deciding!
First up, we've got the **GOWE Mini Pocket Projector**. It has a native resolution of **1280x800** and a brightness of **500 ISO**. The contrast ratio is impressive at **10000:1**, and it supports a decent range of picture sizes from **20 to 115 inches**. The color output is solid with **16.7 million colors**, plus it offers **360-degree image flip** and **manual focus**. On the downside, it runs on an older Android 4.0 system, so you might miss out on some modern features.
Then there's the **SkyEcho Portable Outdoor Projector**. This one boasts **4K video decoding**, which sounds killer for picture quality, plus it has automatic focus and keystone correction, making setup a breeze. The adjustable stand is a nice touch for projecting on different surfaces, but you do have to handle horizontal alignment manually.
So, what do you think? Which projector would give me the best picture and sound quality? Are there any potential downsides I should know about for either one? Your insights will help me make the right choice!
