My friend uses Hisense laser TV and confessed to me. He regret buying a laser TV. The main problem is that there is smearing on the projection. When some of the movies or videos are panned, smearing will occur. Watching during the day, it is also inconvenient to draw curtains. Want to know what are the advantages and disadvantages of Hisense laser TV.
【Laser TV advantage】
1. No installation required
The laser TV itself does not need to be installed, and it is sufficient to find a good location, but if equipped with an anti-light curtain, a professional visitor is required to install it.
2. The picture is as big as the wall
For laser TV, projecting a 100-inch screen is not a problem at all. All you need is a large enough white wall. It is easy to project a 120-inch screen.
3. Moving is convenient
For renters, buying a TV that is too big is a headache every time you move, disassembling and packaging is very troublesome, and there is a risk of broken screen during transportation. The laser projection TV does not need to consider the problem of curtain installation. It can be moved in a box. go.
4. Watching experience stick
The experience brought about by the 100-inch super-large screen is not comparable to that of a 50-inch TV. If you install a sofa butler, you can experience the feeling of a movie theater at home.
【Laser TV Disadvantages】
1. Brightness, insufficient picture quality
Compared with LCD TVs, laser TVs definitely have a gap in brightness, contrast, etc. from LCD TVs. Usually, they are used in shading environments, and the surrounding brightness requirements are relatively high.
2. High requirements on the projection surface.
If you want to improve the viewing effect, you need to be equipped with an anti-light screen. It is not recommended to use an ordinary soft screen, because for ultra-short throw projection, the screen is slightly uneven, which will cause distortion of the screen display, the experience is not ideal, but the hard screen All are relatively expensive, and the price is even as high as tens of thousands of yuan.
3. The price is relatively high
Hisense 75-inch laser TV is more than 10,000 yuan and the price of a mid-to-high-end 70-inch LCD TV is less than 4,000.
The advantages and disadvantages of laser TV are relatively obvious. If you are pursuing the ultimate movie viewing experience brought by a large screen, and convenient transportation needs, you can choose laser TV. If you are difficult to meet the requirements of laser TV playback environment and there is not enough budget, an excellent smart TV is a good choice. In short, there is no best product, only the product that is most suitable for you.
