Nadia
Redmi X 2022 has released in October 2021. Redmi X series smart TV launched in May 2020 which supports both wide color gamut and motion compensation, and at a very low price, so it's still popular today. Will the new product this year be better? Let's see the review.
Redmi X 2022adopts the popular full-screen four-sided narrow bezel design with the common mid-range outward opening eight-sided kickstand. The main body of the bezel is painted silver-gray, and the kickstand is painted black. The bezel is the same as its predecessor, still made of metal, but based on cost-saving considerations, the stitching process is used.
The kickstand is not heavy, but can be found in metal, should be aluminum.
The "Redmi" logo is centered on the bottom edge, and there are also breathing lights, pickup microphones and other modules in this location.
The backside can be seen using a straight down backlighting solution, the middle of the use of reinforcing bars to make the body more stable. The power cord is not unpluggable and the ports are located on the side, with the commonly used ports facing left and the unused ports facing down.
1. Appearance
