sony SONY A9G: ultra 4K OLED panel with ultra X1 Ultimate image processing
Sony A9G, which is released this year, is the third generation of its 4K OLED TV, and the flagship MASTER Series. The A9G, is the top model in the current 4K family (the most advanced model is the 8K resolution Z9G). With the new X1 Ultimate image processor, plus the excellent picture quality of 4K OLED panel support, as well as Android TV system, Acoustic Surface Audio+ Audio effect, specifications are attractive.
X1 Ultimate top-level image processing
SONY TV has done a great job in image processing. The A9G USES the latest generation of the top of the line X1 Ultimate image processor, supports "object-oriented Super pixels", "object-oriented HDR reprofiling", Super Bit Mapping 4K HDR, and dual database processing technology to flexibly detect and analyze each object in an image, resulting in a subtle wealth of detail and contrast. It can take full advantage of the high resolution of the 4K panel to reproduce the original image the creator wanted to present, and it has better results than normal picture line adding technology. In addition, the color, visual Angle and black bit performance of OLED panels are always excellent, while the A9G is equipped with Pixel Contrast Booster technology, which controls more than 8 million self-emitting pixels through SONY original panel controller to obtain better black layer and natural and true color. In addition, the A9G of course supports HDR formats such as HDR10, HLG, and Dolby Vision, and this time has a Netflix calibration mode to better restore the native image when streaming.
Enhanced Acoustic Surface Audio+
The A9G is available in 55, 65 and 77-inch models. The ultra-thin fuselage design can be used with the su-wl850 wall rack installation in addition to the pedestal placement. It can also reduce the distance by about half compared with previous models, making the TV more wall-mounted and better visual effect. The A9G is equipped with sound-to-picture Reality technology and a new Acoustic Surface Audio+ design. With two drives and two ultra-low Sound units, the A9G accurately transmits the Sound of objects from the screen, making the dialogue during the drama more natural and realistic. This new machine also added the middle horn function, connected to the AV receiver when the use of screen sound technology can be used as the middle of surround sound, will further play the above advantages. In addition, the A9G also supports Dolby Atmos sound effects, and can send back 3D sound effects such as Netflix to AV receiver output through the eARC function.
The controls are fast enough and the new menu is easier to use
This time, of course, A9G will continue to use Android TV system. Although compared with Android phones, the number of apps is less than the latter, but for the TV system has been quite rich, there are also MX Player, VLC Player and many other practical programs, and of course, there are YouTube, Netflix, Amazon Video and so on. The built-in Google Assistant makes TVS and homes work smarter, with a built-in radio microphone that lets you voice commands to search for content or play a TV. The menu design has also been improved to make the Settings more convenient. It is worth mentioning that the new processing system is very interesting, this time the control of the A9G response is quite fast, basically one click to arrive, can be I have tried to control the most refreshing SONY TV.
HDR effect outstanding picture smooth and meticulous
We tested the 65-inch model A9G, which is inclined to large size, so the resolution requirement is relatively high. The new flagship processor, the X1 Ultimate, is really good at image processing. Even if you're watching a Netflix original series, the details and noise performance of the UHD blu-ray disc is always worse than that of the real UHD blu-ray disc, but the details presented by the A9G are still very rich.
Many friends may think that the image processor upgrade is just "gimmick", in fact, there is no big difference. However, according to his own experience and everyone can share, the same panel, good treatment and bad treatment can be a huge difference, and sometimes is the most important link to affect the picture quality. Respectively when the test A9G pilot several sets of Netflix streaming and UHD blu-ray discs, indeed it can be seen that the X1 Ultimate image processor is fairly obvious to the promotion of quality, especially the characters and main body, the details of the stereo feeling can be better, even if there is a compressed streaming video does little to rival the entity body plate, the effect of a few surprises. Add in the fine detail of 4K itself, the advantages of OLED in terms of color, visual Angle and black bit, and the picture quality can be said to have no shortcomings.
